PRS Machine 2.0
Kit purchase
Includes Arduino board
PURCHASE LINK
Elite Explorer Kit
Arduino Uno R4 WiFi
3 in 1 Ultimate Starter Kit
Arduino Uno R4 Minima
Course Introduction
In this project, you will use an Arduino board, OLED screen, Active Buzzer, and an Ultrasonic Sensor Module to build a PRS machine2.0.
SN
COMPONENT INTRODUCTION
QUANTITY
PURCHASE LINK
Arduino UNO R4 Minima/Arduino UNO R4 WIFI
USB Type-C cable
Wires
Several
OLED Display Module
Active Buzzer
../_images/RPS_Machine2.0_bb.png
Common Connections:
  • Active Buzzer
    • +: Connect to 3 on the Arduino.
    • -: Connect to breadboard’s negative power bus.
  • Ultrasonic Sensor Module Front
    • Trig: Connect to 10 on the Arduino.
    • Echo: Connect to 11 on the Arduino.
  • OLED Display Module
    • SDA: Connect to A4 on the Arduino.
    • SCK: Connect to A5 on the Arduino.
Writing the Code
  • To install the library, use the Arduino Library Manager and search for Adafruit_GFX and Adafruit SSD1306 and install it.
  • Don’t forget to select the board(Arduino UNO R4 Minima/WIFI) and the correct port before clicking the Upload button.
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
// OLED display settings
#define SCREEN_WIDTH 128
#define SCREEN_HEIGHT 64
#define OLED_RESET -1
#define SCREEN_ADDRESS 0x3C
// Bitmap size
#define ICON_WIDTH 64
#define ICON_HEIGHT 40
// Create OLED object
Adafruit_SSD1306 display(
  SCREEN_WIDTH,
  SCREEN_HEIGHT,
  &Wire,
  OLED_RESET
// Ultrasonic sensor pins
const int trigPin = 10;
const int echoPin = 11;
// Active buzzer pin
const int buzzerPin = 3;
// Prevent repeated triggers
bool hasPlayed = false;
// Icon animation timing
int currentIcon = 0;
unsigned long lastIconTime = 0;
// Time between icon changes
const unsigned long iconInterval = 100;
const uint8_t rockBitmap[] PROGMEM = {
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x00, 0x20, 0x00, 0x7C, 0x7C, 0x00, 0x03, 0x00,
  0x00, 0x00, 0x00, 0xC1, 0x83, 0x00, 0x04, 0x00, 0x00, 0x00, 0x01, 0x80, 0x01, 0xE0, 0x04, 0x00,
  0x00, 0x00, 0x03, 0x00, 0x00, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x06, 0x00, 0x00, 0x18, 0x00, 0x00,
  0x00, 0x00, 0x7C, 0x00, 0x00, 0x0C, 0x00, 0x00, 0x0C, 0x00, 0x60, 0x00, 0x00, 0x0C, 0x00, 0x00,
  0x00, 0x00, 0x80, 0x00, 0x00, 0x0C, 0x00, 0x00, 0x00, 0x00, 0x80, 0x00, 0x02, 0x02, 0x01, 0x80,
  0x00, 0x01, 0x80, 0x02, 0x02, 0x02, 0x01, 0x00, 0x00, 0x01, 0x00, 0x02, 0x01, 0x02, 0x00, 0x00,
  0x00, 0x06, 0x00, 0x01, 0x81, 0x01, 0x00, 0x00, 0xC0, 0x06, 0x01, 0x01, 0x80, 0x81, 0x00, 0x00,
  0x30, 0x04, 0x01, 0x00, 0x40, 0x81, 0x00, 0x00, 0x00, 0x08, 0x00, 0x80, 0x40, 0x41, 0x80, 0x38,
  0x00, 0x18, 0x00, 0x40, 0x20, 0x41, 0x00, 0x00, 0x00, 0x30, 0x00, 0x60, 0x30, 0x23, 0x00, 0x00,
  0x00, 0x30, 0x00, 0x20, 0x30, 0x23, 0x80, 0x00, 0x00, 0x30, 0x20, 0x10, 0x08, 0x3E, 0xE0, 0x00,
  0x00, 0x30, 0x10, 0x18, 0x08, 0x30, 0x60, 0x00, 0x00, 0x30, 0x10, 0x08, 0x04, 0xE2, 0x60, 0x00,
  0x00, 0x30, 0x08, 0x04, 0x07, 0x00, 0x60, 0x00, 0x00, 0x30, 0x08, 0x04, 0x07, 0x00, 0x60, 0x00,
  0x00, 0x18, 0x04, 0x02, 0x1C, 0x00, 0x60, 0x00, 0x00, 0x08, 0x06, 0x03, 0x18, 0x00, 0x60, 0x00,
  0x00, 0x06, 0x01, 0x01, 0xF0, 0x00, 0x80, 0x00, 0x00, 0x07, 0x01, 0x80, 0x60, 0xC1, 0x80, 0x00,
  0x00, 0x01, 0x00, 0x41, 0xA0, 0xDF, 0x00, 0x00, 0x00, 0x00, 0xC0, 0x3E, 0x30, 0xE0, 0x00, 0x00
const uint8_t scissorsBitmap[] PROGMEM = {
  0x00, 0x00, 0x00, 0x0E, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0E, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x11, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x20, 0xC0, 0x00, 0x00, 0x00,
  0x01, 0x00, 0x00, 0x20, 0xC0, 0x00, 0x00, 0x02, 0x00, 0x80, 0x00, 0x20, 0xC0, 0x07, 0xC0, 0x04,
  0x00, 0x40, 0x00, 0x20, 0xC0, 0x08, 0x30, 0x08, 0x00, 0x20, 0x00, 0x20, 0xC0, 0x08, 0x30, 0x30,
  0x00, 0x00, 0x00, 0x20, 0xC0, 0x18, 0x30, 0x00, 0x00, 0x00, 0x00, 0x20, 0xC0, 0x30, 0x20, 0x00,
  0x00, 0x00, 0x00, 0x20, 0xC0, 0x60, 0x60, 0x00, 0x00, 0x00, 0x00, 0x20, 0xC0, 0xC0, 0x80, 0x0C,
  0x00, 0x00, 0x00, 0x20, 0xC1, 0x81, 0x00, 0x00, 0x00, 0x00, 0x00, 0x20, 0xC3, 0x02, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x20, 0xC3, 0x06, 0x00, 0x00, 0x1E, 0x00, 0x00, 0x20, 0xC6, 0x06, 0x00, 0x03,
  0x03, 0x00, 0x00, 0x20, 0xCC, 0x08, 0x00, 0x06, 0x00, 0x00, 0x00, 0x20, 0xD0, 0x10, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x20, 0xF0, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x40, 0x60, 0x60, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x40, 0x00, 0xF8, 0x00, 0x00, 0x00, 0x00, 0x00, 0xC0, 0x01, 0x88, 0x00, 0x00,
  0x00, 0x00, 0x03, 0x7F, 0xC3, 0x08, 0x00, 0x00, 0x00, 0x00, 0x06, 0x00, 0x26, 0x0C, 0x00, 0x00,
  0x00, 0x00, 0x08, 0x00, 0x9C, 0x1E, 0x00, 0x00, 0x03, 0x00, 0x08, 0x00, 0x10, 0x13, 0x00, 0x04,
  0x1E, 0x00, 0x08, 0x00, 0x30, 0x21, 0x00, 0x03, 0x1C, 0x00, 0x08, 0x07, 0xF0, 0xC1, 0x00, 0x01,
  0x00, 0x00, 0x08, 0x01, 0x11, 0x81, 0x00, 0x00, 0x00, 0x00, 0x08, 0x00, 0x8F, 0x07, 0x00, 0x00,
  0x00, 0x00, 0x04, 0x00, 0x82, 0x0E, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x82, 0x18, 0x00, 0x00,
  0x00, 0x00, 0x03, 0x00, 0x81, 0xE8, 0x00, 0x00, 0x00, 0x00, 0x01, 0x81, 0x00, 0x18, 0x00, 0x00
const uint8_t paperBitmap[] PROGMEM = {
  0x00, 0x00, 0x00, 0x00, 0x70, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xF0, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x1D, 0x98, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x22, 0x0F, 0xC0, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x42, 0x0C, 0x40, 0x00, 0x00, 0x00, 0x80, 0x00, 0x42, 0x0C, 0x20, 0x00, 0x04,
  0x00, 0x60, 0x00, 0x42, 0x0C, 0x20, 0x00, 0x18, 0x00, 0x20, 0x00, 0x42, 0x0C, 0x20, 0x00, 0x18,
  0x00, 0x10, 0x00, 0x42, 0x0C, 0x3E, 0x00, 0x00, 0x00, 0x00, 0x00, 0x42, 0x0C, 0x33, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x42, 0x0C, 0x21, 0x00, 0x00, 0x00, 0x00, 0x00, 0x42, 0x0C, 0x21, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x42, 0x0C, 0x21, 0x00, 0x08, 0x00, 0x00, 0x00, 0x42, 0x0C, 0x21, 0x00, 0x30,
  0x03, 0xC0, 0xF8, 0x42, 0x0C, 0x21, 0x00, 0x00, 0x00, 0x00, 0x84, 0x42, 0x0C, 0xE1, 0x00, 0x00,
  0x00, 0x00, 0x83, 0x40, 0x00, 0x21, 0x00, 0x00, 0x00, 0x00, 0x81, 0x40, 0x00, 0x01, 0x00, 0x00,
  0x00, 0x00, 0x80, 0xC0, 0x00, 0x01, 0x00, 0x0F, 0x00, 0x00, 0xC0, 0xC0, 0x00, 0x01, 0x00, 0x0F,
  0x00, 0x00, 0x40, 0x21, 0xF8, 0x01, 0x00, 0x00, 0x00, 0x00, 0x20, 0x3C, 0x03, 0x01, 0x00, 0x00,
  0x01, 0xC0, 0x10, 0x03, 0x00, 0x01, 0x00, 0x00, 0x00, 0x00, 0x08, 0x00, 0xC0, 0x01, 0x00, 0x00,
  0x00, 0x00, 0x08, 0x00, 0x60, 0x01, 0x00, 0x10, 0x00, 0x30, 0x04, 0x00, 0x20, 0x01, 0x00, 0x18,
  0x00, 0x00, 0x04, 0x00, 0x10, 0x01, 0x00, 0x00, 0x00, 0x00, 0x02, 0x00, 0x10, 0x01, 0x00, 0x00,
  0x00, 0x00, 0x03, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x80, 0x00, 0x02, 0x00, 0x00, 0x00, 0x08, 0x00, 0x40, 0x00, 0x06, 0x00, 0x20
  Serial.begin(9600);
  // Configure sensor pins
  pinMode(trigPin, OUTPUT);
  pinMode(echoPin, INPUT);
  // Configure buzzer pin
  pinMode(buzzerPin, OUTPUT);
  // Create a random seed
  randomSeed(analogRead(A0));
  // Initialize OLED
  if (!display.begin(
        SSD1306_SWITCHCAPVCC,
        SCREEN_ADDRESS)) {
    Serial.println("OLED not found");
    while (true);
  display.clearDisplay();
  display.display();
  // Read current distance
  float distance = readDistance();
  Serial.print("Distance: ");
  Serial.print(distance);
  Serial.println(" cm");
  // Object detected
  if (distance > 0 &&
      distance < 9 &&
      !hasPlayed) {
    // Pick a random result
    int result = random(0, 3);
    // Show result immediately
    showIcon(result, true);
    // Let OLED refresh first
    delay(50);
    // Play confirmation sound
    playResultSound();
    hasPlayed = true;
    if (result == 0) {
      Serial.println("Result: ROCK");
    else if (result == 1) {
      Serial.println("Result: SCISSORS");
    else {
      Serial.println("Result: PAPER");
  // Reset when clear
  if (distance >= 20 ||
      distance == -1) {
    hasPlayed = false;
  // Cycle through icons
  if (!hasPlayed) {
    if (millis() - lastIconTime >= iconInterval) {
      lastIconTime = millis();
      showIcon(currentIcon, false);
      currentIcon++;
      if (currentIcon > 2) {
        currentIcon = 0;
  delay(30);
// Measure distance in cm
float readDistance() {
  // Send trigger pulse
  digitalWrite(trigPin, LOW);
  delayMicroseconds(2);
  digitalWrite(trigPin, HIGH);
  delayMicroseconds(10);
  long duration =
    pulseIn(
      echoPin,
      HIGH,
      30000
  // No echo received
  if (duration == 0) {
    return -1;
  // Convert to centimeters
  return duration / 58.0;
// Display selected icon
// 0 = Rock
// 1 = Scissors
// 2 = Paper
void showIcon(
  int icon,
  bool isResult) {
  if (isResult) {
    drawSparkles();
  if (icon == 0) {
    display.drawBitmap(
      32,
      5,
      rockBitmap,
      ICON_WIDTH,
      ICON_HEIGHT,
      SSD1306_WHITE
    drawLabel("ROCK", 52);
  else if (icon == 1) {
    display.drawBitmap(
      32,
      5,
      scissorsBitmap,
      ICON_WIDTH,
      ICON_HEIGHT,
      SSD1306_WHITE
    drawLabel("SCISSORS", 40);
  else {
    display.drawBitmap(
      32,
      5,
      paperBitmap,
      ICON_WIDTH,
      ICON_HEIGHT,
      SSD1306_WHITE
    drawLabel("PAPER", 49);
  display.display();
// Draw icon label
void drawLabel(
  const char *text,
  int x) {
  display.setTextColor(
    SSD1306_WHITE);
  display.setTextSize(1);
  display.setCursor(x, 54);
  display.println(text);
// Draw result effect
void drawSparkles() {
  display.drawLine(
    14, 18,
    22, 18,
    SSD1306_WHITE);
  display.drawLine(
    18, 14,
    18, 22,
    SSD1306_WHITE);
  display.drawLine(
    106, 18,
    114, 18,
    SSD1306_WHITE);
  display.drawLine(
    110, 14,
    110, 22,
    SSD1306_WHITE);
  display.drawLine(
    14, 42,
    22, 42,
    SSD1306_WHITE);
  display.drawLine(
    18, 38,
    18, 46,
    SSD1306_WHITE);
  display.drawLine(
    106, 42,
    114, 42,
    SSD1306_WHITE);
  display.drawLine(
    110, 38,
    110, 46,
    SSD1306_WHITE);
// Play a simple confirmation beep
void playResultSound() {
  digitalWrite(
    buzzerPin,
    HIGH);
  delay(120);
  digitalWrite(
    buzzerPin,
    LOW);
  delay(80);
  digitalWrite(
    buzzerPin,
    HIGH);
  delay(120);
  digitalWrite(
    buzzerPin,
    LOW);
