2.3 Colorful Light
In this project, we will delve into the fascinating world of additive color mixing using an RGB LED.
RGB LED combines three primary colors, namely Red, Green, and Blue, into a single package. These three LEDs share a common cathode pin, while each anode pin controls the intensity of the corresponding color.
By varying the electrical signal intensity applied to each anode, we can create a wide range of colors. For example, mixing high-intensity red and green light will result in yellow light, while combining blue and green light will produce cyan.
Through this project, we will explore the principles of additive color mixing and unleash our creativity by manipulating the RGB LED to display captivating and vibrant colors.
ITEMS IN THIS KIT
ESP32 Starter Kit
320+
ESP32 Starter Kit
COMPONENT INTRODUCTION
PURCHASE LINK
ESP32 Board
ESP32 Camera Extension
Jumper Wires
Resistor
RGB LED
Available Pins
Here is a list of available pins on the ESP32 board for this project.
Available Pins
Schematic
../../_images/circuit_2.3_rgb.png
The PWM pins pin27, pin26 and pin25 control the Red, Green and Blue pins of the RGB LED respectively, and connect the common cathode pin to GND. This allows the RGB LED to display a specific color by superimposing light on these pins with different PWM values.
../../_images/rgb_pin.jpg
The RGB LED has 4 pins: the long pin is the common cathode pin, which is usually connected to GND; the left pin next to the longest pin is Red; and the two pins on the right are Green and Blue.
../../_images/2.3_color_light_bb.png
Here, we can choose our favorite color in drawing software (such as paint) and display it with RGB LED.
  • You can open the file 2.3_rgb_led.ino under the path of esp32-starter-kit-main\c\codes\2.3_rgb_led.
  • After selecting the board (ESP32 Dev Module) and the appropriate port, click the Upload button.
  • Always displaying “Unknown COMxx”?
../../_images/edit_colors.png
Write the RGB value into color_set(), you will be able to see the RGB light up the colors you want.
How it works?
  1. Define the GPIO pins, the PWM channels and the frequency (in Hz) and resolution (in bits).
    // Define RGB LED pins
    const int redPin = 27;
    const int greenPin = 26;
    const int bluePin = 25;
    // Define PWM frequency and resolution
    const int freq = 5000;
    const int resolution = 8;
  2. The setup() function initializes the PWM channels with the specified frequency and resolution, and then attaches the LED pins to their corresponding PWM channels.
      // Set up PWM pins
      ledcAttach(redPin, freq, resolution);
      ledcAttach(greenPin, freq, resolution);
      ledcAttach(bluePin, freq, resolution);
    Here we use the LEDC (LED control) peripheral which is primarly designed to control the intensity of LEDs, although it can also be used to generate PWM signals for other purposes.
    • bool ledcAttach(uint8_t pin, uint32_t freq, uint8_t resolution);: This function is used to setup LEDC pin with given frequency and resolution. LEDC channel will be selected automatically.
      • pin select GPIO pin.
      • freq select frequency of pwm.
      • resolution_bits select resolution for ledc channel. Range is 1-14 bits (1-20 bits for ESP32).
  3. The loop() function cycles through various colors (red, green, blue, yellow, purple, and cyan) with one-second intervals between each color change.
        setColor(255, 0, 0); // Red
        delay(1000);
        setColor(0, 255, 0); // Green
        delay(1000);
        setColor(0, 0, 255); // Blue
        delay(1000);
        setColor(255, 255, 0); // Yellow
        delay(1000);
        setColor(80, 0, 80); // Purple
        delay(1000);
        setColor(0, 255, 255); // Cyan
        delay(1000);
  4. The setColor() function sets the desired color by writing the appropriate duty cycle values to each PWM channel. The function takes in three integer arguments for red, green, and blue color values.
    void setColor(int red, int green, int blue) {
      ledcWrite(redPin, red);
      ledcWrite(greenPin, green);
      ledcWrite(bluePin, blue);
    • bool ledcWrite(uint8_t pin, uint32_t duty);: This function is used to set duty for the LEDC pin.
      • pin select LEDC pin.
      • duty select duty to be set for selected channel.
