8.4 IoT Communication with MQTT
This project focuses on utilizing MQTT, a popular communication protocol in the Internet of Things (IoT) domain. MQTT enables IoT devices to exchange data using a publish/subscribe model, where devices communicate through topics.
In this project, we explore the implementation of MQTT by building a circuit that includes an LED, a button, and a thermistor. The ESP32 board microcontroller is used to establish a connection to WiFi and communicate with an MQTT broker. The code allows the microcontroller to subscribe to specific topics, receive messages, and control the LED based on the received information. Additionally, the project demonstrates publishing temperature data from the thermistor to a designated topic when the button is pressed.
ITEMS IN THIS KIT
ESP32 Starter Kit
320+
ESP32 Starter Kit
COMPONENT INTRODUCTION
PURCHASE LINK
ESP32 Board
ESP32 Camera Extension
Jumper Wires
Resistor
LED
Button
Thermistor
Code Upload
  1. Build the circuit.
    When establishing a connection to WiFi, only the 36, 39, 34, 35, 32, 33 pins can be employed for analog reading. Please ensure the thermistor is connected to these designated pins.
    ../../_images/iot_4_matt_bb.png
  2. Then, connect ESP32 board to the computer using the USB cable.
  3. Open the code.
    • Open the iot_4_mqtt.ino file located in the esp32-starter-kit-main\c\codes\iot_4_mqtt directory, or copy the code into the Arduino IDE.
    • After selecting the board (ESP32 Dev Module) and the appropriate port, click the Upload button.
    • Always displaying “Unknown COMxx”?
    • The PubSubClient library is used here, you can install it from the Library Manager.
      ../../_images/mqtt_lib.png
  4. Locate the following lines and modify them with your SSID and PASSWORD.
    // Replace the next variables with your SSID/Password combination
    const char* ssid = "SSID";
    const char* password = "PASSWORD";
  5. Find the next line and modify your unique_identifier. Guarantee that your unique_identifier is truly unique as any IDs that are identical trying to log in to the same MQTT Broker may result in a login failure.
    // Add your MQTT Broker address, example:
    const char* mqtt_server = "broker.hivemq.com";
    const char* unique_identifier = "sunfounder-client-sdgvsda";
Topic Subscription
  1. To avoid interference from messages sent by other participants, you can set it as an obscure or uncommon string. Simply replace the current topic SF/LED with your desired topic name.
    You have the freedom to set the Topic as any character you desire. Any MQTT device that has subscribed to the identical Topic will be able to receive the same message. You can also simultaneously subscribe to multiple Topics.
    void reconnect() {
        // Loop until we're reconnected
        while (!client.connected()) {
            Serial.print("Attempting MQTT connection...");
            // Attempt to connect
            if (client.connect(unique_identifier)) {
                Serial.println("connected");
                // Subscribe
                client.subscribe("SF/LED");
            } else {
                Serial.print("failed, rc=");
                Serial.print(client.state());
                Serial.println(" try again in 5 seconds");
                // Wait 5 seconds before retrying
                delay(5000);
  2. Modify the functionality to respond to the subscribed topic. In the provided code, if a message is received on the topic SF/LED, it checks whether the message is on or off. Depending on the received message, it changes the output state to control the LED’s on or off status.
    You can modify it for any topic you are subscribed to, and you can write multiple if statements to respond to multiple topics.
    void callback(char* topic, byte* message, unsigned int length) {
        Serial.print("Message arrived on topic: ");
        Serial.print(topic);
        Serial.print(". Message: ");
        String messageTemp;
        for (int i = 0; i < length; i++) {
            Serial.print((char)message[i]);
            messageTemp += (char)message[i];
        Serial.println();
        // If a message is received on the topic "SF/LED", you check if the message is either "on" or "off".
        // Changes the output state according to the message
        if (String(topic) == "SF/LED") {
            Serial.print("Changing state to ");
            if (messageTemp == "on") {
                Serial.println("on");
                digitalWrite(ledPin, HIGH);
            } else if (messageTemp == "off") {
                Serial.println("off");
                digitalWrite(ledPin, LOW);
  3. After selecting the correct board (ESP32 Dev Module) and port, click the Upload button.
  4. Open the serial monitor and if the following information is printed, it indicates a successful connection to the MQTT server.
    WiFi connected
    IP address:
    192.168.18.77
    Attempting MQTT connection...connected
Message Publication via HiveMQ
HiveMQ is a messaging platform that functions as an MQTT broker, facilitating fast, efficient, and reliable data transfer to IoT devices.
Our code specifically utilizes the MQTT broker provided by HiveMQ. We have included the address of the HiveMQ MQTT broker in the code as follows:
  1. At present, open the HiveMQ Web Client in your web browser.
  2. Connect the client to the default public proxy.
    ../../_images/sp230512_092258.png
  3. Publish a message in the Topic you have subscribed to. In this project, you can publish on or off to control your LED.
    ../../_images/sp230512_140234.png
Message Publication to MQTT
We can also utilize the code to publish information to the Topic. In this demonstration, we have coded a feature that sends the temperature measured by the thermistor to the Topic when you press the button.
  1. Click on Add New Topic Subscription.
    ../../_images/sp230512_092341.png
  2. Fill in the topics you desire to follow and click Subscribe. In the code, we send temperature information to the topic SF/TEMP.
        if (!client.connected()) {
            reconnect();
        client.loop();
        // if the button pressed, publish the temperature to topic "SF/TEMP"
        if (digitalRead(buttonPin)) {
                long now = millis();
                if (now - lastMsg > 5000) {
                lastMsg = now;
                char tempString[8];
                dtostrf(thermistor(), 1, 2, tempString);
                client.publish("SF/TEMP", tempString);
  3. Hence, we can monitor this Topic on HiveMQ, allowing us to view the information you have published.
    ../../_images/sp230512_154342.png
