7.1 Bluetooth
This project provides a guide to develop a simple Bluetooth Low Energy (BLE) serial communication application using the ESP32 microcontroller. The ESP32 is a powerful microcontroller that integrates Wi-Fi and Bluetooth connectivity, making it an ideal candidate for developing wireless applications. BLE is a low-power wireless communication protocol that is designed for short-range communication. This document will cover the steps to set up the ESP32 to act as a BLE server and communicate with a BLE client over a serial connection.
About the Bluetooth Function
The ESP32 board is a module that integrates Wi-Fi and Bluetooth connectivity into a single chip. It supports Bluetooth Low Energy (BLE) and Classic Bluetooth protocols.
The module can be used as a Bluetooth client or server. As a Bluetooth client, the module can connect to other Bluetooth devices and exchange data with them. As a Bluetooth server, the module can provide services to other Bluetooth devices.
The ESP32 board supports various Bluetooth profiles, including the Generic Access Profile (GAP), Generic Attribute Profile (GATT), and Serial Port Profile (SPP). The SPP profile allows the module to emulate a serial port over Bluetooth, enabling serial communication with other Bluetooth devices.
To use the Bluetooth function of the ESP32 board, you need to program it using an appropriate software development kit (SDK) or using the Arduino IDE with the ESP32 BLE library. The ESP32 BLE library provides a high-level interface for working with BLE. It includes examples that demonstrate how to use the module as a BLE client and server.
Overall, the Bluetooth function of the ESP32 board provides a convenient and low-power way to enable wireless communication in your projects.
Operation Steps
Here are the step-by-step instructions to set up Bluetooth communication between your ESP32 and mobile device using the LightBlue app:
  1. Download the LightBlue app from the App Store (for iOS) or Google Play (for Android).
    ../../_images/bluetooth_lightblue.png
  2. Open the 7.1_bluetooth.ino file located in the esp32-starter-kit-main\c\codes\7.1_bluetooth directory, or copy the code into the Arduino IDE.
  3. To avoid UUID conflicts, it is recommended to randomly generate three new UUIDs using the Online UUID Generator, and fill them in the following lines of code.
    #define SERVICE_UUID           "your_service_uuid_here"
    #define CHARACTERISTIC_UUID_RX "your_rx_characteristic_uuid_here"
    #define CHARACTERISTIC_UUID_TX "your_tx_characteristic_uuid_here"
    ../../_images/uuid_generate.png
  4. Select the correct board and port, then click the Upload button.
    ../../_images/bluetooth_upload.png
  5. After the code has been successfully uploaded, turn on Bluetooth on your mobile device and open the LightBlue app.
    ../../_images/bluetooth_open.png
  6. On the Scan page, find ESP32-Bluetooth and click CONNECT. If you don’t see it, try refreshing the page a few times. When “Connected to device!” appears, the Bluetooth connection is successful. Scroll down to see the three UUIDs set in the code.
    ../../_images/bluetooth_connect.png
  7. Click the Receive UUID. Select the appropriate data format in the box to the right of Data Format, such as “HEX” for hexadecimal, “UTF-8 String” for character, or “Binary” for binary, etc. Then click SUBSCRIBE.
    ../../_images/bluetooth_read.png
  8. Go back to the Arduino IDE, open the Serial Monitor, set the baud rate to 115200, then type “welcome” and press Enter.
    ../../_images/bluetooth_serial.png
  9. You should now see the “welcome” message in the LightBlue app.
    ../../_images/bluetooth_welcome.png
  10. To send information from the mobile device to the Serial Monitor, click the Send UUID, set the data format to “UTF-8 String”, and write a message.
    ../../_images/bluetooth_send.png
  11. You should see the message in the Serial Monitor.
    ../../_images/bluetooth_receive.png
How it works?
This Arduino code is written for the ESP32 microcontroller and sets it up to communicate with a Bluetooth Low Energy (BLE) device.
The following is a brief summary of the code:
  • Include necessary libraries: The code begins by including necessary libraries for working with Bluetooth Low Energy (BLE) on the ESP32.
    #include "BLEDevice.h"
    #include "BLEServer.h"
    #include "BLEUtils.h"
    #include "BLE2902.h"
  • Global Variables: The code defines a set of global variables including the Bluetooth device name (bleName), variables to keep track of received text and the time of the last message, UUIDs for the service and characteristics, and a BLECharacteristic object (pCharacteristic).
    // Define the Bluetooth device name
    const char *bleName = "ESP32_Bluetooth";
    // Define the received text and the time of the last message
    String receivedText = "";
    unsigned long lastMessageTime = 0;
    // Define the UUIDs of the service and characteristics
    // Define the Bluetooth characteristic
    BLECharacteristic *pCharacteristic;
  • Setup: In the setup() function, the serial port is initialized with a baud rate of 115200 and the setupBLE() function is called to set up the Bluetooth BLE.
        Serial.begin(115200);  // Initialize the serial port
        setupBLE();            // Initialize the Bluetooth BLE
  • Main Loop: In the loop() function, if a string was received over BLE (i.e., receivedText is not empty) and at least 1 second has passed since the last message, the code prints the received string to the serial monitor, sets the characteristic value to the received string, sends a notification, and then clears the received string. If data is available on the serial port, it reads the string until a newline character is encountered, sets the characteristic value to this string, and sends a notification.
        // When the received text is not empty and the time since the last message is over 1 second
        // Send a notification and print the received text
        if (receivedText.length() > 0 && millis() - lastMessageTime > 1000) {
            Serial.print("Received message: ");
            Serial.println(receivedText);
            pCharacteristic->setValue(receivedText.c_str());
            pCharacteristic->notify();
            receivedText = "";
        // Read data from the serial port and send it to BLE characteristic
        if (Serial.available() > 0) {
            String str = Serial.readStringUntil('\n');
            const char *newValue = str.c_str();
            pCharacteristic->setValue(newValue);
  • Callbacks: Two callback classes (MyServerCallbacks and MyCharacteristicCallbacks) are defined to handle events related to Bluetooth communication. MyServerCallbacks is used to handle events related to the connection state (connected or disconnected) of the BLE server. MyCharacteristicCallbacks is used to handle write events on the BLE characteristic, i.e., when a connected device sends a string to the ESP32 over BLE, it’s captured and stored in receivedText, and the current time is recorded in lastMessageTime.
    // Define the BLE server callbacks
    class MyServerCallbacks : public BLEServerCallbacks {
        // Print the connection message when a client is connected
        void onConnect(BLEServer *pServer) {
        Serial.println("Connected");
        // Print the disconnection message when a client is disconnected
        void onDisconnect(BLEServer *pServer) {
        Serial.println("Disconnected");
    // Define the BLE characteristic callbacks
    class MyCharacteristicCallbacks : public BLECharacteristicCallbacks {
        void onWrite(BLECharacteristic *pCharacteristic) {
            // When data is received, get the data and save it to receivedText, and record the time
            std::string value = std::string(pCharacteristic->getValue().c_str());
            receivedText = String(value.c_str());
            lastMessageTime = millis();
            Serial.print("Received: ");
  • Setup BLE: In the setupBLE() function, the BLE device and server are initialized, the server callbacks are set, the BLE service is created using the defined UUID, characteristics for sending notifications and receiving data are created and added to the service, and the characteristic callbacks are set. Finally, the service is started and the server begins advertising.
    void setupBLE() {
        BLEDevice::init(bleName);                        // Initialize the BLE device
        BLEServer *pServer = BLEDevice::createServer();  // Create the BLE server
        // Print the error message if the BLE server creation fails
        if (pServer == nullptr) {
            Serial.println("Error creating BLE server");
            return;
        pServer->setCallbacks(new MyServerCallbacks());  // Set the BLE server callbacks
        // Create the BLE service
        BLEService *pService = pServer->createService(SERVICE_UUID);
        // Print the error message if the BLE service creation fails
        if (pService == nullptr) {
            Serial.println("Error creating BLE service");
            return;
        // Create the BLE characteristic for sending notifications
        pCharacteristic = pService->createCharacteristic(CHARACTERISTIC_UUID_TX, BLECharacteristic::PROPERTY_NOTIFY);
        pCharacteristic->addDecodeor(new BLE2902());  // Add the decodeor
        // Create the BLE characteristic for receiving data
        BLECharacteristic *pCharacteristicRX = pService->createCharacteristic(CHARACTERISTIC_UUID_RX, BLECharacteristic::PROPERTY_WRITE);
        pCharacteristicRX->setCallbacks(new MyCharacteristicCallbacks());  // Set the BLE characteristic callbacks
        pService->start();                                                 // Start the BLE service
        pServer->getAdvertising()->start();                                // Start advertising
        Serial.println("Waiting for a client connection...");              // Wait for a client connection
Please note that this code allows for bidirectional communication - it can send and receive data via BLE. However, to interact with specific hardware like turning on/off an LED, additional code should be added to process the received strings and act accordingly.
