RGB LED¶
RGB LEDs emit light in various colors. An RGB LED packages three LEDs of red, green, and blue into a transparent or semitransparent plastic shell. It can display various colors by changing the input voltage of the three pins and superimpose them, which, according to statistics, can create 16,777,216 different colors.
Features
Color: Tri-Color (Red/Green/Blue)
Common Cathode
5mm Clear Round Lens
Forward Voltage: Red: DC 2.0 - 2.2V; Blue&Green: DC 3.0 - 3.2V (IF=20mA)
0.06 Watts DIP RGB LED
Luminance Brighter Up To +20%
Viewing Angle: 30°
Common Anode and Common Cathode
RGB LEDs can be categorized into common anode and common cathode ones.
In a common cathode RGB LED, all three LEDs share a negative connection (cathode).
In a common anode RGB LED, the three LEDs share a positive connection (anode).
We use the common cathode one.
RGB LED Pins
An RGB LED has 4 pins: the longest one is GND; the others are Red, Green and Blue. Place the RGB LEDs as shown, so that the longest lead is second from the left. Then the pin numbers of the RGB LEDs should be Red, GND, Green and Blue.
You can also use the multimeter to select Diode Test mode, and then connect as shown below to measure the color of each pin.
Mix colors
To generate additional colors, you can combine the three colors at different intensities. To adjust the intensity of each LED, you can use a PWM signal.
Because the LEDs are so close to each other, our eyes see the result of the color combination rather than the three colors individually.
Check out the table below to see how the colors are combined. It will give you an idea of how the color mixing chart works and how different colors are produced.
Example
2.3 Colorful Light (Arduino Project)
6.5 Color Gradient (Arduino Project)
2.3 Colorful Light (MicroPython Project)
2.3 Colorful Balls (Scratch Project)
