6.5 Color Gradient¶
Are you ready to experience a world of color? This project will take you on a magical journey where you can control an RGB LED and achieve smooth color transitions. Whether you’re looking to add some color to your home decor or seeking a fun programming project, this project has got you covered. Let’s dive into this colorful world together!
ESP32 Starter Kit |
320+ |
COMPONENT INTRODUCTION |
PURCHASE LINK |
Schematic
The RGB LED has 4 pins: the long pin is the common cathode pin, which is usually connected to GND; the left pin next to the longest pin is Red; and the two pins on the right are Green and Blue.
You can open the file
6.5_color_gradient.inounder the path ofesp32-starter-kit-main\c\codes\6.5_color_gradient.After selecting the board (ESP32 Dev Module) and the appropriate port, click the Upload button.
This project uses an RGB LED and a potentiometer to create a color mixing effect. The potentiometer is used to adjust the hue value of the LED, which is then converted into RGB values using a color conversion function. The RGB values are then used to update the color of the LED.
How it works?
This project builds upon the 2.3 Colorful Light project by adding a potentiometer to adjust the hue value of the LED. The hue value is then converted to RGB values using a color conversion function.
In the loop function, read the value of the potentiometer and convert it to a hue value (0-360).
int knobValue = analogRead(KNOB_PIN); float hueValue = (float) knobValue / 4095.0; int hue = (int) (hueValue * 360);
Convert the hue value to RGB values using the
HUEtoRGB()function, and update the LED with the new color values.int red, green, blue; HUEtoRGB(hue, &red, &green, &blue); setColor(red, green, blue);
The
setColor()function sets the value of the red, green, and blue channels using theLEDClibrary.void setColor(int red, int green, int blue) { ledcWrite(redPin, red); ledcWrite(greenPin, green); ledcWrite(bluePin, blue); }
The
HUEtoRGBfunction converts a hue value to RGB values using the HSL color model.void HUEtoRGB(int hue, int* red, int* green, int* blue) { float h = (float) hue / 60.0; float c = 1.0; float x = c * (1.0 - fabs(fmod(h, 2.0) - 1.0)); float r, g, b; if (h < 1.0) { r = c; g = x; b = 0; ...
