5.12 Measuring Distance
The ultrasonic module is used for distance measurement or object detection. In this project, we will program the module to obtain obstacle distances. By sending ultrasonic pulses and measuring the time it takes for them to bounce back, we can calculate distances. This enables us to implement distance-based actions or obstacle avoidance behaviors.
ITEMS IN THIS KIT
ESP32 Starter Kit
320+
ESP32 Starter Kit
COMPONENT INTRODUCTION
PURCHASE LINK
ESP32 Board
ESP32 Camera Extension
Jumper Wires
Ultrasonic Module
Available Pins
  • Available Pins
    Here is a list of available pins on the ESP32 board for this project.
    For Input
    IO13, IO14, IO27, IO26, IO25, IO33, IO32, I35, I34, I39, I36, IO4, IO18, IO19, IO21, IO22, IO23
    For Output
Schematic
../../_images/circuit_5.12_ultrasonic.png
The ESP32 sends a set of square wave signals to the Trig pin of the ultrasonic sensor every 10 seconds. This prompts the ultrasonic sensor to emit a 40kHz ultrasound signal outward. If there is an obstacle in front, the ultrasound waves will be reflected back.
By recording the time it takes from sending to receiving the signal, dividing it by 2, and multiplying it by the speed of light, you can determine the distance to the obstacle.
../../_images/5.12_ultrasonic_bb.png
  • Open the 5.12_ultrasonic.ino file under the path of esp32-starter-kit-main\c\codes\5.12_ultrasonic.
  • After selecting the board (ESP32 Dev Module) and the appropriate port, click the Upload button.
  • Always displaying “Unknown COMxx”?
Remember to Set the serial communication baud rate to 115200.
After the code is successfully uploaded, the serial monitor will print out the distance between the ultrasonic sensor and the obstacle ahead.
How it works?
About the application of ultrasonic sensor, we can directly check the subfunction.
float readSensorData(){// ...}
  • The trigPin of the ultrasonic module transmits a 10us square wave signal every 2us.
    // Trigger a low signal before sending a high signal
    digitalWrite(trigPin, LOW);
    delayMicroseconds(2);
    // Send a 10-microsecond high signal to the trigPin
    digitalWrite(trigPin, HIGH);
    delayMicroseconds(10);
    // Return to low signal
  • The echoPin receives a high level signal if there is an obstacle within the range and use the pulseIn() function to record the time from sending to receiving.
    unsigned long microsecond = pulseIn(echoPin, HIGH);
  • The speed of sound is 340 meters per second, which is equivalent to 29 microseconds per centimeter. By measuring the time it takes for a square wave to travel to an obstacle and return, we can calculate the distance traveled by dividing the total time by 2. This gives us the distance of the obstacle from the source of the sound wave.
    float distance = microsecond / 29.00 / 2;
Note that the ultrasonic sensor will pause the program when it is working, which may cause some lagging when writing complex projects.
