6.4 Digital Dice
This project builds upon the 2.5 Number Display project by adding a button to control the digit displayed on the seven-segment display.
In this project, a random number is generated and displayed on the seven-segment display to simulate a dice roll. When the button is pressed, a stable number (randomly selected from 1 to 6) is displayed on the seven-segment display. Pressing the button again will initiate the simulation of a dice roll, generating random numbers as before. This cycle continues each time the button is pressed.
ITEMS IN THIS KIT
ESP32 Starter Kit
320+
ESP32 Starter Kit
COMPONENT INTRODUCTION
PURCHASE LINK
ESP32 Board
ESP32 Camera Extension
Jumper Wires
Resistor
74HC595
7-segment Display
Button
Schematic
../../_images/circuit_6.6_electronic_dice.png
This project builds upon the 2.5 7 Segment Display project by adding a button to control the digit displayed on the seven-segment display.
The button is directly connected to IO13 without an external pull-up or pull-down resistor because IO13 has an internal pull-up resistor of 47K, eliminating the need for an additional external resistor.
../../_images/6.6_DICE_bb.png
  • Open the 6.4_digital_dice.ino file under the path of esp32-starter-kit-main\c\codes\6.4_digital_dice.
  • After selecting the board (ESP32 Dev Module) and the appropriate port, click the Upload button.
  • Always displaying “Unknown COMxx”?
This project is based on 2.5 7 Segment Display with a button to start/pause the scrolling display on the 7-segment Display.
When the button is pressed, the 7-segment display scrolls through the numbers 1-6, and when the button is released, it displays a random number.
