8.2 Camera Web Server
This project combines the ESP32 board with a camera module to stream high-quality video over a local network. Set up your own camera system effortlessly and monitor any location in real-time.
With the project’s web interface, you can access and control the camera feed from any device connected to the network. Customize camera settings to optimize the streaming experience and easily adjust settings with the user-friendly interface.
Enhance your surveillance or live streaming capabilities with the versatile ESP32 Camera Streaming project. Monitor your home, office, or any desired location with ease and reliability.
ITEMS IN THIS KIT
ESP32 Starter Kit
320+
ESP32 Starter Kit
COMPONENT INTRODUCTION
PURCHASE LINK
ESP32 Board
ESP32 Camera Extension
How to do?
  1. First plug in the camera.
  2. Then, connect ESP32 board to the computer using the USB cable.
  3. Open the code.
    • Open the iot_2_camera_server.ino file located in the esp32-starter-kit-main\c\codes\iot_2_camera_server directory, or copy the code into the Arduino IDE.
    • After selecting the board (ESP32 Dev Module) and the appropriate port, click the Upload button.
    • Always displaying “Unknown COMxx”?
  4. Locate the following lines and modify them with your SSID and PASSWORD.
    // Enter your WiFi credentials
    const char *ssid = "*****************";
    const char *password = "*************";
  5. Now, enable PSRAM.
    ../../_images/sp230516_1505541.png
  6. Set the partition scheme to Huge APP (3MB No OTA/1MB SPIFFS).
    ../../_images/sp230516_1508401.png
  7. After selecting the correct board (ESP32 Dev Module) and port, click the “Upload” button.
  8. You will see a successful WiFi connection message and the assigned IP address in the Serial Monitor.
    WiFi connected
    Starting web server on port: '80'
    Starting stream server on port: '81'
    Camera Ready! Use 'http://192.168.18.77' to connect
  9. Enter the IP address in your web browser. You will see a web interface where you can click Start Stream to view the camera feed.
    ../../_images/sp230516_151521.png
  10. Scroll back to the top of the page, where you will see the live camera feed. You can adjust the settings on the left side of the interface.
    ../../_images/sp230516_180520.png
