5.3 Detect the Obstacle
This module is commonly installed on the car and robot to judge the existence of the obstacles ahead. Also it is widely used in hand held device, water faucet and so on.
ITEMS IN THIS KIT
ESP32 Starter Kit
320+
ESP32 Starter Kit
COMPONENT INTRODUCTION
PURCHASE LINK
ESP32 Board
ESP32 Camera Extension
Jumper Wires
Obstacle Avoidance Module
Available Pins
  • Available Pins
    Here is a list of available pins on the ESP32 board for this project.
    Available Pins
    IO13, IO14, IO27, IO26, IO25, IO33, I35, I34, I39, I36, IO4, IO18, IO19, IO21, IO22, IO23
  • Strapping Pins (Input)
    Strapping pins are a special set of pins that are used to determine specific boot modes during device startup (i.e., power-on reset).
    Strapping Pins
    IO5, IO0, IO2, IO12, IO15
    Generally, it is not recommended to use them as input pins. If you wish to use these pins, consider the potential impact on the booting process. For more details, please refer to the Strapping Pins section.
Schematic
../../_images/circuit_5.3_avoid.png
When the obstacle avoidance module does not detect any obstacles, IO14 returns a high level. However, when it detects an obstacle, it returns a low level. You can adjust the blue potentiometer to modify the detection distance of this module.
../../_images/5.3_avoid_bb.png
  • You can open the file 5.3.detect_the_obstacle.ino under the path of esp32-starter-kit-main\c\codes\5.3.detect_the_obstacle.
  • After selecting the board (ESP32 Dev Module) and the appropriate port, click the Upload button.
  • Always displaying “Unknown COMxx”?
Set the serial communication baud rate to 115200. After the code is uploaded successfully, if the IR obstacle avoidance module detects something blocking in front of it, “0” will appear on the serial monitor, otherwise “1” will be displayed.
