4.1 Motor¶
In this engaging project, we’ll explore how to drive a motor using the L293D.
The L293D is a versatile integrated circuit (IC) commonly used for motor control in electronics and robotics projects. It can drive two motors in both forward and reverse directions, making it a popular choice for applications requiring precise motor control.
By the end of this captivating project, you will have gained a thorough understanding of how digital signals and PWM signals can effectively be utilized to control motors. This invaluable knowledge will prove to be a solid foundation for your future endeavors in robotics and mechatronics. Buckle up and get ready to dive into the exciting world of motor control with the L293D!
ESP32 Starter Kit |
320+ |
COMPONENT INTRODUCTION |
PURCHASE LINK |
Available Pins
Here is a list of available pins on the ESP32 board for this project.
Available Pins |
IO13, IO14, IO27, IO26, IO25, IO33, IO32, IO15, IO2, IO0, IO4, IO5, IO18, IO19, IO21, IO22, IO23 |
Schematic
Since the motor requires a relatively high current, it is necessary to first insert the Power Pack and then slide the switch on the expansion board to the ON position to activate the power supply.
Open the
4.1_motor.inofile under the path ofesp32-starter-kit-main\c\codes\4.1_motor.After selecting the board (ESP32 Dev Module) and the appropriate port, click the Upload button.
Once the code is successfully uploaded, you will observe the motor rotating clockwise for one second, then counter-clockwise for one second, followed by a two-second pause. This sequence of actions will continue in an endless loop.
Learn More
In addition to simply making the motor rotate clockwise and counterclockwise, you can also control the speed of the motor’s rotation by using pulse-width modulation (PWM) on the control pin, as shown below.
Open the
4.1_motor_pwm.inofile under the path ofesp32-starter-kit-main\c\codes\4.1_motor_pwm.After selecting the board (ESP32 Dev Module) and the appropriate port, click the Upload button.
The previous code directly sets the two pins of the motor to high or low voltage levels to control the motor’s rotation and stopping.
Here we use the LEDC (LED control) peripheral to generate PWM signals to control the motor’s speed. Through two for loops, the duty cycle of channel A is increased or decreased from 0 to 255 while keeping channel B at 0.
This way, you can observe the motor gradually increasing its speed to 255, then decreasing to 0, infinitely looping like this.
If you want the motor to rotate in the opposite direction, simply swap the values of channel A and channel B.
