2.5 7 Segment Display
Welcome to this fascinating project! In this project, we will explore the enchanting world of displaying numbers from 0 to 9 on a seven-segment display.
Imagine triggering this project and witnessing a small, compact display glowing brightly with each number from 0 to 9. It’s like having a miniature screen that showcases the digits in a captivating way. By controlling the signal pins, you can effortlessly change the displayed number and create various engaging effects.
Through simple circuit connections and programming, you will learn how to interact with the seven-segment display and bring your desired numbers to life. Whether it’s a counter, a clock, or any other intriguing application, the seven-segment display will be your reliable companion, adding a touch of brilliance to your projects.
ITEMS IN THIS KIT
ESP32 Starter Kit
320+
ESP32 Starter Kit
COMPONENT INTRODUCTION
PURCHASE LINK
ESP32 Board
ESP32 Camera Extension
Jumper Wires
Resistor
7-segment Display
74HC595
Available Pins
Here is a list of available pins on the ESP32 board for this project.
Available Pins
Schematic
../../_images/circuit_2.5_74hc595_7_segment.png
Here the wiring principle is basically the same as 2.4 Microchip - 74HC595, the only difference is that Q0-Q7 are connected to the a ~ g pins of the 7 Segment Display.
74HC595
LED Segment Display
Q0
a
Q1
b
Q2
c
Q3
d
Q4
e
Q5
f
Q6
g
Q7
dp
../../_images/2.5_segment_bb.png
  • Open the 2.5_7segment.ino file under the path of esp32-starter-kit-main\c\codes\2.5_7segment.
  • After selecting the board (ESP32 Dev Module) and the appropriate port, click the Upload button.
  • Always displaying “Unknown COMxx”?
After the code is uploaded successfully, you will be able to see the LED Segment Display display 0~9 in sequence.
How it works?
In this project, we are using the shiftOut() function to write the binary number to the shift register.
Suppose that the 7-segment Display display the number “2”. This bit pattern corresponds to the segments f, c and dp being turned off (low), while the segments a, b, d, e and g are turned on (high). This is “01011011” in binary and “0x5b” in hexadecimal notation.
Therefore, you would need to call shiftOut(DS,SHcp,MSBFIRST,0x5b) to display the number “2” on the 7-segment display.
../../_images/7_segment2.png
The following table shows the hexadecimal patterns that need to be written to the shift register to display the numbers 0 to 9 on a 7-segment display.
Glyph Code
Numbers
Binary Code
Hex Code
0
00111111
0x3f
0x06
0x5b
0x4f
0x66
0x6d
0x7d
7
00000111
0x07
8
01111111
0x7f
9
01101111
0x6f
Write these codes into shiftOut() to make the LED Segment Display display the corresponding numbers.
