7.5 MP3 Player with SD Card Support
Welcome to the exciting world of music with your ESP32! This project brings the power of audio processing to your fingertips, making your ESP32 not just an amazing microcontroller for computing but also your personalized music player. Imagine walking into your room and having your favorite track playing right from this tiny device. That’s the power we’re bringing to your hands today.
ITEMS IN THIS KIT
ESP32 Starter Kit
320+
ESP32 Starter Kit
COMPONENT INTRODUCTION
PURCHASE LINK
ESP32 Board
ESP32 Camera Extension
Jumper Wires
Resistor
Audio Module and Speaker
Operating Steps
  1. Insert your SD card into the computer using a card reader, and then format it. You can refer to the tutorial at How to format the SD card?.
  2. Copy your favorite MP3 file to your SD card.
    ../../_images/mp3_music.png
  3. Insert the SD card into the SD card slot of the extension board.
    ../../_images/insert_sd.png
  4. Build the circuit.
    As this is a mono amplifier, you can connect IO25 to the L or R pin of the audio amplifier module.
    The 10K resistor is used to reduce high-frequency noise and lower the audio volume. It forms an RC low-pass filter with the parasitic capacitance of the DAC and audio amplifier. This filter decreases the amplitude of high-frequency signals, effectively reducing high-frequency noise. So, adding the 10K resistor makes the music sound softer and eliminates unwanted high-frequency noise.
    If your SD card’s music is already soft, you can remove or replace the resistor with a smaller value.
    ../../_images/7.3_bluetooth_audio_player_bb.png
  5. Connect ESP32 board to the computer using the USB cable.
  6. Modify the code.
    Modify the line of code file = new AudioFileSourceSD_MMC("/To Alice.mp3"); to reflect your file’s name and path.
    • Open the 7.5_mp3_player_sd.ino file under the path of esp32-starter-kit-main\c\codes\7.5_mp3_player_sd. Or copy this code into Arduino IDE.
    • After selecting the board (ESP32 Dev Module) and the appropriate port, click the Upload button.
    • Always displaying “Unknown COMxx”?
    • The ESP8266Audio library is used here, refer to Manual Installation for a tutorial to install.
    Warning
    If you are using an ESP32 development board version 3.0.0 or higher, you may encounter errors during the compilation process. This issue is usually because the newer versions of the board no longer support the ESP8266Audio library. To properly run this example, it is recommended to downgrade your ESP32 board’s firmware version to 2.0.17. After completing this example, upgrade back to the latest version.
    ../../_images/version_2.0.17.png
  7. Select the appropriate port and board in the Arduino IDE and upload the code to your ESP32.
  8. After successfully uploading the code, you will hear your favorite music playing.
How it works?
  • The code uses several classes from the ESP8266Audio library to play an MP3 file from an SD card through I2S:
    #include "AudioFileSourceSD_MMC.h"
    #include "AudioOutputI2S.h"
    #include "AudioGeneratorMP3.h"
    #include "SD_MMC.h"
    #include "FS.h"
    • AudioGeneratorMP3 is a class that decodes MP3 audio.
    • AudioFileSourceSD_MMC is a class that reads audio data from an SD card.
    • AudioOutputI2S is a class that sends audio data to the I2S interface.
  • In the setup() function, we initialize the SD card, open the MP3 file from the SD card, set up the I2S output on the ESP32’s internal DAC, set the output to mono, and start the MP3 generator.
        // Start the serial communication.
        Serial.begin(115200);
        delay(1000);
        // Initialize the SD card. If it fails, print an error message.
        if (!SD_MMC.begin()) {
            Serial.println("SD card mount failed!");
        // Open the MP3 file from the SD card. Replace "/To Alice.mp3" with your own MP3 file name.
        // Set up the I2S output on ESP32's internal DAC.
        out = new AudioOutputI2S(0, 1);
        // Set the output to mono.
        out->SetOutputModeMono(true);
        // Initialize the MP3 generator with the file and output.
        mp3 = new AudioGeneratorMP3();
        mp3->begin(file, out);
  • In the loop() function, we check if the MP3 generator is running. If it is, we continue looping it; otherwise, we stop it and print “MP3 done” to the serial monitor.
        // If the MP3 is running, loop it. Otherwise, stop it.
        if (mp3->isRunning()) {
            if (!mp3->loop()) mp3->stop();
        // If the MP3 is not running, print a message and wait for 1 second.
        else {
            Serial.println("MP3 done");
            delay(1000);
