5.13 Temperature - Humidity
The DHT11 is a temperature and humidity sensor commonly used for environmental measurements. It is a digital sensor that communicates with a microcontroller to provide temperature and humidity readings.
In this project, we will be reading the DHT11 sensor and printing out the temperature and humidity values it detects.
By reading the data provided by the sensor, we can obtain the current temperature and humidity values in the environment. These values can be used for real-time monitoring of environmental conditions, weather observations, indoor climate control, humidity reports, and more.
ITEMS IN THIS KIT
ESP32 Starter Kit
320+
ESP32 Starter Kit
COMPONENT INTRODUCTION
PURCHASE LINK
ESP32 Board
ESP32 Camera Extension
Jumper Wires
DHT11 Humiture Sensor
  • Available Pins
    Here is a list of available pins on the ESP32 board for this project.
    Available Pins
    IO13, IO12, IO14, IO27, IO26, IO25, IO33, IO15, IO2, IO0, IO4, IO5, IO18, IO19, IO21, IO22, IO23
Schematic
../../_images/circuit_5.13_dht11.png
../../_images/5.13_dht11_bb.png
  • Open the 5.13_dht11.ino file under the path of esp32-starter-kit-main\c\codes\5.13_dht11.
  • After selecting the board (ESP32 Dev Module) and the appropriate port, click the Upload button.
  • Always displaying “Unknown COMxx”?
  • The DHT sensor library library is used here, you can install it from the Library Manager.
    ../../_images/dht_lib.png
Remember to Set the serial communication baud rate to 115200.
After the code is uploaded successfully, you will see the Serial Monitor continuously print out the temperature and humidity, and as the program runs steadily, these two values will become more and more accurate.
How it works?
  1. Includes the DHT.h library, which provides functions to interact with the DHT sensors. Then, set the pin and type for the DHT sensor.
    #include "DHT.h"
    #define DHTPIN 14  // Set the pin connected to the DHT11 data pin
    #define DHTTYPE DHT11 // DHT 11
    DHT dht(DHTPIN, DHTTYPE);
  2. Initializes serial communication at a baud rate of 115200 and initializes the DHT sensor.
        Serial.begin(115200);
        Serial.println("DHT11 test!");
        dht.begin();
  3. In the loop() function, read temperature and humidity values from the DHT11 sensor, and print them to the serial monitor.
        // Wait a few seconds between measurements.
        delay(2000);
        float humidity = dht.readHumidity();
        float temperture = dht.readTemperature();
        if (isnan(humidity) || isnan(temperture)) {
            return;
        // Print the humidity and temperature
        Serial.print("Humidity: ");
        Serial.print(humidity);
        Serial.print(" %\t");
        Serial.print("Temperature: ");
        Serial.print(temperture);
        Serial.println(" *C");
    • The dht.readHumidity() function is called to read the humidity value from the DHT sensor.
    • The dht.readTemperature() function is called to read the temperature value from the DHT sensor.
    • The isnan() function is used to check if the readings are valid. If either the humidity or temperature value is NaN (not a number), it indicates a failed reading from the sensor, and an error message is printed.
Learn More
You can also display the temperature and humidity on the I2C LCD1602.
  • You can open the file 5.10_thermistor_lcd.ino under the path of euler-kit/arduino/5.10_thermistor_lcd.
  • The LiquidCrystal_I2C and DHT sensor library libraries are used here, you can install them from the Library Manager.
