1.3 Install the ESP32 Board(Important)¶
To program the ESP32 microcontroller, we need to install the ESP32 board package in the Arduino IDE. Follow the step-by-step guide below:
In the Boards Manager window, type ESP32 in the search bar. Click the Install button to start the installation process. This will download and install the ESP32 board package.
Congratulations! You have successfully installed the ESP32 board package in the Arduino IDE.
Upload the Code
Now, connect the ESP32 board to your computer using a USB cable.
Then select the correct board, ESP32 Dev Module, by clicking on Tools -> Board -> esp32.
If your ESP32 is connected to the computer, you can choose the correct port by clicking on Tools -> Port.
If it shows COM1 or no port, your computer may not recognize the board. See Manually Install Driver for ESP32.
Additionally, Arduino 2.0 introduced a new way to quickly select the board and port. For ESP32, it is usually not automatically recognized, so you need to click on Select other board and port.
In the search box, type ESP32 Dev Module and select it when it appears. Then, choose the correct port and click OK.
Afterward, you can select it through this quick access window. Note that during subsequent use, there may be times when ESP32 is not available in the quick access window, and you will need to repeat the above two steps.
Both methods allow you to select the correct board and port, so choose the one that suits you best. Now, everything is ready to upload the code to the ESP32.
