Lesson 47: Bluetooth Traffic Light
This project is designed to control a traffic light (Red, Yellow, Green LEDs) using Bluetooth communication. The user can send a character (‘R’, ‘Y’, or ‘G’) from a Bluetooth device. When the Arduino receives one of these characters, it lights up the corresponding LED, while ensuring the other two LEDs are turned off.
Universal Maker Sensor Kit |
94 |
Component Introduction |
Purchase Link |
Arduino UNO R3 or R4 |
App and Bluetooth module Connection
We can use an app called “Serial Bluetooth Terminal” to send messages from the Bluetooth module to Arduino.
Install Serial Bluetooth Terminal
Go to Google Play to download and install Serial Bluetooth Terminal .
Connect Bluetooth
Initially, turn on Bluetooth on your smartphone.
Navigate to the Bluetooth settings on your smartphone and look for names like JDY-31-SPP.
After clicking it, agree to the Pair request in the pop-up window. If prompted for a pairing code, please enter “1234”.
Communicate with Bluetooth module
Open the Serial Bluetooth Terminal. Connect to “JDY-31-SPP”.
Send command
Use the Serial Bluetooth Terminal app to send commands to Arduino via Bluetooth. Send R to turn on the red light, Y for yellow, and G for green.
Code Analysis
Initialization and Bluetooth setup
// Set up Bluetooth module communication #include <SoftwareSerial.h> const int bluetoothTx = 3; const int bluetoothRx = 4; SoftwareSerial bleSerial(bluetoothTx, bluetoothRx);
We begin by including the SoftwareSerial library to help us with Bluetooth communication. The Bluetooth module’s TX and RX pins are then defined and associated with pins 3 and 4 on the Arduino. Finally, we initialize the
bleSerialobject for Bluetooth communication.LED Pin Definitions
// Pin numbers for each LED const int rledPin = 10; //red const int yledPin = 11; //yellow const int gledPin = 12; //green
Here, we’re defining which Arduino pins our LEDs are connected to. The red LED is on pin 10, yellow on 11, and green on 12.
setup() Function
void setup() { pinMode(rledPin, OUTPUT); pinMode(yledPin, OUTPUT); pinMode(gledPin, OUTPUT); Serial.begin(9600); bleSerial.begin(9600); }
In the
setup()function, we set the LED pins asOUTPUT. We also start serial communication for both the Bluetooth module and the default serial (connected to the computer) at a baud rate of 9600.Main loop() for Bluetooth Communication
void loop() { while (bleSerial.available() > 0) { character = bleSerial.read(); Serial.println(character); if (character == 'R') { toggleLights(rledPin); } else if (character == 'Y') { toggleLights(yledPin); } else if (character == 'G') { toggleLights(gledPin); } } }
Inside our main
loop(), we continuously check if data is available from the Bluetooth module. If we receive data, we read the character and display it in the serial monitor. Depending on the character received (R, Y, or G), we toggle the respective LED using thetoggleLights()function.Toggle Lights Function
void toggleLights(int targetLight) { digitalWrite(rledPin, LOW); digitalWrite(yledPin, LOW); digitalWrite(gledPin, LOW); digitalWrite(targetLight, HIGH); }
This function,
toggleLights(), turns off all the LEDs first. After ensuring they are all off, it turns on the specified target LED. This ensures that only one LED is on at a time.
