Lesson 15: Raindrop Detection Moduleο
In this lesson, you will learn how to use a Raindrop Detection Sensor Module with an Arduino. We will see how the sensor detects rain by measuring changes in resistance caused by raindrops completing circuits on its nickel-coated surface.
Required Componentsο
Universal Maker Sensor Kit |
94 |
Component Introduction |
Purchase Link |
Arduino UNO R3 or R4 |
Wiringο
Codeο
Code Analysisο
Defining sensor pin
Here, a constant integer named
sensorPinis defined and assigned the value 7. This corresponds to the digital pin on the Arduino board where the raindrops detection sensor is connected.const int sensorPin = 7;
Setting up the pin mode and initiating serial communication.
In the
setup()function, two essential steps are performed. Firstly,pinMode()is used to set thesensorPinas an input, enabling us to read digital values from the raindrops sensor. Secondly, serial communication is initialized with a baud rate of 9600.void setup() { pinMode(sensorPin, INPUT); Serial.begin(9600); }
Reading the digital value and sending it to the serial monitor.
The
loop()function reads the digital value from the raindrops sensor usingdigitalRead(). This value (either HIGH or LOW) is printed to the Serial Monitor. When raindrops are detected, the serial monitor will display 0; when no raindrops are detected, it will display 1. The program then waits for 50 milliseconds before the next reading.void loop() { Serial.println(digitalRead(sensorPin)); delay(50); }
