For Raspberry Pi
Raspberry Pi users, please refer to the following tutorial. This tutorial is based on Raspberry Pi 5 as an example and has been verified on Raspberry Pi 4 and Raspberry Pi 5, but may also be applicable to other versions of Raspberry Pi (not guaranteed).
We will program the Raspberry Pi using the GPIO Zero library in Python, providing simple code examples for each component to help you get started quickly.
The GPIO Zero library is a remarkable tool in Python designed for interfacing with the GPIO (General Purpose Input/Output) pins on a Raspberry Pi. It offers a straightforward and intuitive API, making it exceptionally accessible for beginners in electronics and programming. The library simplifies tasks such as reading sensors, controlling motors, and activating LEDs, allowing for seamless interaction with a wide array of hardware components. Its user-friendly nature encourages experimentation and learning, making it a popular choice in educational environments and DIY projects.
- Lesson 01: Button Module
- Lesson 02: Capacitive Soil Moisture Module
- Lesson 03: Flame Sensor Module
- Lesson 04: Gas Sensor Module (MQ-2)
- Lesson 05: Gyroscope & Accelerometer Module (MPU6050)
- Lesson 06: Hall Sensor Module
- Lesson 07: Infrared Speed Sensor Module
- Lesson 08: IR Obstacle Avoidance Sensor Module
- Lesson 09: Joystick Module
- Lesson 10: PCF8591 ADC DAC Converter Module
- Lesson 11: Photoresistor Module
- Lesson 12: PIR Motion Module (HC-SR501)
- Lesson 13: Potentiometer Module
- Lesson 14: Pulse Oximeter and Heart Rate Sensor Module (MAX30102)
- Lesson 15: Raindrop Detection Module
- Lesson 17: Rotary Encoder Module
- Lesson 18: Temperature Sensor Module (DS18B20)
- Lesson 19: Temperature and Humidity Sensor Module (DHT11)
- Lesson 20: Temperature, Humidity & Pressure Sensor (BMP280)
- Lesson 21: Time of Flight Micro-LIDAR Distance Sensor (VL53L0X)
- Lesson 22: Touch Sensor Module
- Lesson 23: Ultrasonic Sensor Module (HC-SR04)
- Lesson 24: Vibration Sensor Module (SW-420)
- Lesson 25: Water Level Sensor Module
- Lesson 26: I2C LCD 1602
- Lesson 27: OLED Display Module (SSD1306)
- Lesson 28: RGB Module
- Lesson 29: Traffic Light Module
- Lesson 30: Relay Module
- Lesson 31: Centrifugal Pump
- Lesson 32: Passive Buzzer Module
- Lesson 33: Servo Motor (SG90)
- Lesson 34: TT Motor
