Traffic Light Moduleο
The traffic light module is a small device that can display red, yellow and green lights, just like a real traffic light. It can be used to make a traffic light system model or to learn how to control LEDs with Arduino. It is featured with its small size, simple wiring, targeted, and custom installation. It can be connected PWM pin to control the brightness of the LED.
Principleο
The traffic light module can be controlled in two primary ways. The more straightforward method involves using digital inputs from the Arduino, where a HIGH or LOW signal directly turns the corresponding LED on or off. Alternatively, PWM (pulse-width modulation) can be used, especially when varying the brightness of the LED is desired. PWM is a technique where the duty cycle of a digital signal is changed to modulate the brightness of the LED. A duty cycle represents the percentage of time that a signal remains on during a specific period. For instance, a 50% duty cycle implies the signal is active for half the duration and inactive for the remainder. Adjusting the duty cycle allows for the LEDβs brightness modulation.
Schematic diagramο
Exampleο
Lesson 29: Traffic Light Module (Arduino UNO)
Lesson 29: Traffic Light Module (ESP32)
Lesson 30: Relay Module (Raspberry Pi Pico)
Lesson 30: Relay Module (Raspberry Pi)
Lesson 30: Relay Module (Arduino UNO)
Lesson 42: Touch toggle light (Arduino UNO)
Lesson 47: Bluetooth Traffic Light (Arduino UNO)
Lesson 40: Touch toggle light (ESP32)
