Lesson 36: Get Started with Bluetooth Module
In this project, we demonstrate how to communicate with a Bluetooth module through Arduino.
Firstly, we need to set up the circuit and use software serial communication. Connect the TX pin of the Bluetooth module to pin 3 of the Uno board, and connect the RX pin of the Bluetooth module to pin 4 of the Uno board.
ITEMS IN THIS KIT
Universal Maker Sensor Kit
94
Component Introduction
Purchase Link
Arduino UNO R3 or R4
JDY-31 Bluetooth Module
1. Build the Circuit
../_images/Lesson_36_Bluetooth_uno_bb.png
2. Upload the code
The code establishes a software serial communication using Arduino’s SoftwareSerial library, allowing the Arduino to communicate with the JDY-31 Bluetooth module through its digital pins 3 and 4 (as Rx and Tx). It checks for data transfer between them, forwarding received messages from one to the other at a baud rate of 9600. With this code, you can use the Arduino’s serial monitor to send AT commands to the JDY-31 Bluetooth module and receive its responses.
3. Configuring the Bluetooth module
Click the magnifying glass icon (Serial Monitor) in the upper right corner and set the baud rate to 9600. Then, select both NL & CR from the drop-down option of the New Line dropdown box.
../_images/Lesson_36_bluetooth_serial_1_shadow.png
The following are some examples of using AT commands to configure Bluetooth modules: Enter AT+NAME to obtain the name of the Bluetooth device. If you want to modify the Bluetooth name, please add a new name after AT+NAME.
  • Query the name of a Bluetooth device: AT+NAME
    ../_images/Lesson_36_bluetooth_serial_2.gif
  • Set Bluetooth device name: AT+NAME (following by the new name). +OK means the setting was successful. You can send AT+NAME again to verify.
    ../_images/Lesson_36_bluetooth_serial_3.gif
To ensure consistency in the learning experience, it is recommended not to modify the default baud rate of the Bluetooth module and keep it at its default value of 4 (i.e. 9600 baud rate). In relevant courses, we communicate with Bluetooth using a baud rate of 9600.
  • Set Bluetooth baudrate: AT+BAUD (followed by the number indicating the baudrate).
    • 4 == 9600
    • 5 == 19200
    • 6 == 38400
    • 7 == 57600
    • 8 == 115200
    • 9 == 128000
Please refer to the table below for more AT commands.
Command
Function
Default
AT+VERSION
Version Number
JDY-31-V1.2
AT+RESET
Soft reset
AT+DISC
Disconnect (valid when connected)
AT+LADDR
Query the MAC address of the module
AT+PIN
Set or query connection password
1234
AT+BAUD
Set or query baud rate
9600
AT+NAME
Set or query broadcast name
JDY-31-SPP
AT+DEFAULT
Factory reset
AT+ENLOG
Serial port status output
4. Communicating through Bluetooth debugging tools on mobile phones
We can use an app called “Serial Bluetooth Terminal” to send messages from the Bluetooth module to Arduino, simulating the process of Bluetooth interaction. The Bluetooth module will send received messages to Arduino through serial port, and similarly, Arduino can also send messages to bluetooth module through serial port.
  1. Install Serial Bluetooth Terminal
    Go to Google Play to download and install Serial Bluetooth Terminal .
  2. Connect Bluetooth
    Initially, turn on Bluetooth on your smartphone.
    Navigate to the Bluetooth settings on your smartphone and look for names like JDY-31-SPP.
    After clicking it, agree to the Pair request in the pop-up window. If prompted for a pairing code, please enter “1234”.
  3. Communicate with Bluetooth module
    Open the Serial Bluetooth Terminal. Connect to “JDY-31-SPP”.
    ../_images/Lesson_36_bluetooth_serial_4_shadow.png
    After successful connection, you can see the prompt of successful connection in the serial port monitor.
    ../_images/Lesson_36_bluetooth_serial_5_shadow.png
    Input the message in the serial monitor and send it to the Bluetooth module.
    ../_images/Lesson_36_bluetooth_serial_6_shadow.png
    After sending, you can see this message in the Serial Bluetooth Terminal APP. Similarly, data can be sent to Arduino via Bluetooth in Serial Bluetooth Terminal APP.
    ../_images/Lesson_36_bluetooth_serial_7_shadow.png
    You can see this message from Bluetooth in the serial monitor.
    ../_images/Lesson_36_bluetooth_serial_8_shadow.png
