Lesson 46: Bluetooth LCD
This project enables the receipt of messages via a Bluetooth module connected to an Arduino UNO board and displays these messages on an LCD screen.
Universal Maker Sensor Kit |
94 |
Component Introduction |
Purchase Link |
Arduino UNO R3 or R4 |
To install the library, use the Arduino Library Manager and search for “LiquidCrystal I2C” and install it.
App and Bluetooth module Connection
We can use an app called “Serial Bluetooth Terminal” to send messages from the Bluetooth module to Arduino.
Install Serial Bluetooth Terminal
Go to Google Play to download and install Serial Bluetooth Terminal .
Connect Bluetooth
Initially, turn on Bluetooth on your smartphone.
Navigate to the Bluetooth settings on your smartphone and look for names like JDY-31-SPP.
After clicking it, agree to the Pair request in the pop-up window. If prompted for a pairing code, please enter “1234”.
Communicate with Bluetooth module
Open the Serial Bluetooth Terminal. Connect to “JDY-31-SPP”.
Send command
Use the Serial Bluetooth Terminal app to send messages to Arduino via Bluetooth. The message sent to Bluetooth will be displayed on the LCD.
Code Analysis
To install library, use the Arduino Library Manager and search for “LiquidCrystal I2C” and install the library.
Setting up the LCD
#include <LiquidCrystal_I2C.h> LiquidCrystal_I2C lcd(0x27, 16, 2);
This segment of code includes the LiquidCrystal_I2C library and initializes the LCD module with the I2C address as
0x27and specifies that the LCD has16columns and2rows.Setting up Bluetooth communication
#include <SoftwareSerial.h> const int bluetoothTx = 3; const int bluetoothRx = 4; SoftwareSerial bleSerial(bluetoothTx, bluetoothRx);
Here, the SoftwareSerial library is included to allow the JDY-31 Bluetooth module to communicate with the Arduino using pins 3 (TX) and 4 (RX).
Initialization
void setup() { lcd.init(); lcd.clear(); lcd.backlight(); Serial.begin(9600); bleSerial.begin(9600); }
The
setup()function initializes the LCD and clears any existing content. It also turns on the backlight for the LCD. Communication is started with the serial monitor and the Bluetooth module, both at a baud rate of9600.Main Loop
void loop() { String data; if (bleSerial.available()) { data += bleSerial.readString(); data = data.substring(0, data.length() - 2); Serial.print(data); lcd.clear(); lcd.setCursor(0, 0); lcd.print(data); } if (Serial.available()) { bleSerial.write(Serial.read()); } }
This is the main operational loop of the Arduino program. It continually checks for incoming data from both the Bluetooth module and the serial monitor. When data is received from the Bluetooth device, it’s processed, displayed on the serial monitor, and shown on the LCD. If data is entered into the serial monitor, this data is sent to the Bluetooth module.
