Lesson 52: Tilt Direction Indicator
This Arduino project uses an MPU6050 accelerometer and gyroscope sensor along with an OLED display. The project reads data from the MPU6050 sensor to detect the tilt direction and displays corresponding arrows (up, down, left, or right) or a circle (if there is no significant tilt) on the OLED screen based on the tilt direction.
ITEMS IN THIS KIT
Universal Maker Sensor Kit
94
Component Introduction
Purchase Link
Arduino UNO R3 or R4
Gyroscope & Accelerometer Module (MPU6050)
OLED Display Module (SSD1306)
../_images/Lesson_52_Tilt_direction_indicatorr_uno_bb.png
To install the library, use the Arduino Library Manager and search for “Adafruit SSD1306” and “Adafruit GFX” and install it.
Code Analysis
  1. Library inclusion and OLED display setup
    The project starts by including the necessary libraries to interface with the MPU6050 sensor and OLED display. The OLED display dimensions and I2C address are defined, followed by the creation of the display object.
    #include <Adafruit_MPU6050.h>
    #include <Adafruit_Sensor.h>
    #include <Wire.h>
    #include <Adafruit_GFX.h>
    #include <Adafruit_SSD1306.h>
    #define SCREEN_WIDTH 128
    #define SCREEN_HEIGHT 64
    #define OLED_RESET -1
    #define SCREEN_ADDRESS 0x3C
    Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
    Adafruit_MPU6050 mpu;
  2. Setup function
    In the setup function, the serial communication is initialized, and the MPU6050 sensor is initialized with specific settings for accelerometer and gyroscope ranges. The OLED display is also initialized and cleared.
    void setup(void) {
      Serial.begin(115200);
      if (!mpu.begin()) {
        Serial.println("Failed to find MPU6050 chip");
        while (1) {
          delay(10);
      mpu.setAccelerometerRange(MPU6050_RANGE_8_G);
      mpu.setGyroRange(MPU6050_RANGE_500_DEG);
      mpu.setFilterBandwidth(MPU6050_BAND_21_HZ);
      if (!display.begin(SSD1306_SWITCHCAPVCC, SCREEN_ADDRESS)) {
        Serial.println(F("SSD1306 allocation failed"));
        for (;;)
          ;  // Don't proceed, loop forever
      display.clearDisplay();
      delay(100);
  3. Loop function
    In the loop function, sensor data is continuously read, and the tilt direction is determined based on acceleration values. Depending on the tilt direction, different arrows or a circle are drawn on the OLED display.
    The code reads data from the MPU6050 sensor to detect the tilt direction and displays corresponding arrows (up, down, left, or right) or a circle (if there is no significant tilt) on the OLED screen based on the tilt direction.
      sensors_event_t a, g, temp;
      mpu.getEvent(&a, &g, &temp);
      Serial.print("acceleration:");
      Serial.print(a.acceleration.x);
      Serial.print(",");
      Serial.print(a.acceleration.y);
      Serial.print(",");
      Serial.println(a.acceleration.z);
      if (a.acceleration.x >= 2) {
        drawUpArrow();
      } else if (a.acceleration.x <= -2) {
        drawDownArrow();
      } else if (a.acceleration.y >= 2) {
        drawLeftArrow();
      } else if (a.acceleration.y <= -2) {
        drawRightArrow();
      } else {
        drawCircle();
      display.display();
      delay(200);
  4. Drawing functions
    Several helper functions are defined to draw different shapes on the OLED display. These functions use the Adafruit_GFX library to draw arrows and circles.
    void drawUpArrow() {
      display.fillTriangle(49, 30, 64, 15, 79, 30, WHITE);
      display.fillRect(59, 30, 10, 20, WHITE);
    void drawDownArrow() {
      display.fillTriangle(49, 36, 64, 51, 79, 36, WHITE);
      display.fillRect(59, 16, 10, 20, WHITE);
    void drawRightArrow() {
      display.fillTriangle(70, 15, 85, 30, 70, 45, WHITE);
      display.fillRect(50, 25, 20, 10, WHITE);
    void drawLeftArrow() {
      display.fillTriangle(60, 15, 45, 30, 60, 45, WHITE);
      display.fillRect(60, 25, 20, 10, WHITE);
    void drawCircle() {
      display.fillCircle(64, 32, 10, WHITE);
      display.fillCircle(64, 32, 8, BLACK);
Reference
