Lesson 06: Hall Sensor Module
In this lesson, you will learn how a Hall sensor detects magnetic fields using Arduino. We’ll explore how to read the sensor’s analog signal with Arduino Uno, interpreting the values to determine the polarity of a magnetic field. You’ll understand the workings of the Hall sensor, and how the Arduino board processes and displays these readings in real-time.
Universal Maker Sensor Kit |
94 |
Component Introduction |
Purchase Link |
Arduino UNO R3 or R4 |
Code Analysis
Setting up the Hall Sensor
const int hallSensorPin = A0; // Pin A0 connected to the Hall sensor output void setup() { Serial.begin(9600); // Initialize serial communication at 9600 bps pinMode(hallSensorPin, INPUT); // Set hall sensor pin as input }
The hall sensor’s output is connected to pin A0 on the Arduino. The
setup()function is used to initialize serial communication at 9600 bits per second (bps) for displaying data on the serial monitor. ThepinMode()function is used to configure A0 as an input pin.Reading from the Hall Sensor and Determining Polarity
The Hall sensor module is equipped with a 49E linear Hall effect sensor, which can measure the polarity of the magnetic field’s north and south poles as well as the relative strength of the magnetic field. If you place a magnet’s south pole near the side marked with 49E (the side with text engraved on it), the value read by the code will increase linearly in proportion to the applied magnetic field strength. Conversely, if you place a north pole near this side, the value read by the code will decrease linearly in proportion to that magnetic field strength. For more details, please refer to Hall Sensor Module.
void loop() { int sensorValue = analogRead(hallSensorPin); // Read analog value from Hall sensor Serial.print(sensorValue); // Output raw sensor value to Serial Monitor delay(200); // Delay for 200 milliseconds // Determine magnetic pole based on sensor value if (sensorValue >= 700) { Serial.print(" - South pole detected"); // South pole detected if value >= 700 } else if (sensorValue <= 300) { Serial.print(" - North pole detected"); // North pole detected if value <= 300 } Serial.println(); // New line for next output }
