Lesson 03: Flame Sensor Module
In this lesson, you will learn how to integrate a flame sensor with an Arduino board to detect the presence of fire. We will see how the flame sensor, when detecting a flame, triggers the Arduino’s built-in LED to light up and sends a warning message to the serial monitor. Conversely, in the absence of a flame, the LED stays off, and a different message is relayed to the monitor. This project is an excellent starting point for beginners, offering a comprehensive understanding of how to manage digital inputs and outputs on the Arduino platform. It provides a hands-on approach to learning about sensor integration and real-time response mechanisms in an Arduino-based system.
Universal Maker Sensor Kit |
94 |
Component Introduction |
Purchase Link |
Arduino UNO R3 or R4 |
Code Analysis
The first line of code is a constant integer declaration for the flame sensor pin. We use the digital pin 7 to read the output from the flame sensor.
const int sensorPin = 7;
The
setup()function initializes the flame sensor pin as an input and the built-in LED pin as an output. It also starts the serial communication at a baud rate of 9600 for printing messages to the serial monitor.void setup() { pinMode(sensorPin, INPUT); // Set the flame sensor pin as input pinMode(LED_BUILTIN, OUTPUT); // Set the built-in LED pin as output Serial.begin(9600); // Initialize the serial monitor at a baud rate of 9600 }
The
loop()function is where we continuously check the status of the flame sensor. If the sensor detects a flame, the built-in LED is turned on and a message is printed to the serial monitor. If no flame is detected, the LED is turned off and a different message is printed. The process repeats every 100 milliseconds.Note
You can change the threshold for detecting flames by adjusting the potentiometer on the flame sensor module.
void loop() { // Check if the sensor is detecting a fire if (digitalRead(sensorPin) == 0) { digitalWrite(LED_BUILTIN, HIGH); // Turn on the built-in LED Serial.println("** Fire detected!!! **"); } else { digitalWrite(LED_BUILTIN, LOW); // Turn off the built-in LED Serial.println("No Fire detected"); } delay(100); }
