Lesson 34: TT Motor
In this lesson, you will learn how to control a motor using an Arduino Uno R3 or R4 and an L9110 motor control board. We’ll cover defining motor pins and setting their speed through programming. This tutorial will walk you through the process of connecting and controlling a motor, demonstrating the basic principles of motor operation and control in Arduino projects. Geared towards beginners, this lesson provides a hands-on approach to understanding output operations on the Arduino platform.
Universal Maker Sensor Kit |
94 |
Component Introduction |
Purchase Link |
Arduino UNO R3 or R4 |
Code Analysis
The first part of the code defines the motor control pins. These are connected to the L9110 motor control board.
// Define the motor pins const int motorB_1A = 9; const int motorB_2A = 10;
The
setup()function initializes the motor control pins as output using thepinMode()function. Then it usesanalogWrite()to set the speed of the motor. The value passed toanalogWrite()can range from 0 (off) to 255 (full speed). Adelay()function is then used to pause the code for 5000 milliseconds (or 5 seconds), after which the motor speed is set to 0 (off).void setup() { pinMode(motorB_1A, OUTPUT); // set motor pin 1 as output pinMode(motorB_2A, OUTPUT); // set motor pin 2 as output analogWrite(motorB_1A, 255); // set motor speed (0-255) analogWrite(motorB_2A, 0); delay(5000); analogWrite(motorB_1A, 0); analogWrite(motorB_2A, 0); }
