Lesson 30: Relay Module
In this lesson, you will learn how to use a relay and an Arduino Uno to control a traffic light module. We’ll demonstrate how to turn the red light of the traffic module on and off using the relay. This project is ideal for beginners in Arduino, providing hands-on experience in controlling external modules and gaining a fundamental understanding of relay operations.
Universal Maker Sensor Kit |
94 |
Component Introduction |
Purchase Link |
Arduino UNO R3 or R4 |
Code Analysis
Setting up the relay pin:
The relay module is connected to pin 6 of the Arduino. This pin is defined as
relayPinfor ease of reference in the code.
const int relayPin = 6;
Configuring the relay pin as an output:
In the
setup()function, the relay pin is set as an OUTPUT using thepinMode()function. This means the Arduino will send signals (either HIGH or LOW) to this pin.
void setup() { pinMode(relayPin, OUTPUT); }
Toggling the relay ON and OFF:
In the
loop()function, the relay is first set to the OFF state usingdigitalWrite(relayPin, LOW). It remains in this state for 3 seconds (delay(3000)).Then, the relay is set to the ON state using
digitalWrite(relayPin, HIGH). Again, it remains in this state for 3 seconds.This cycle repeats indefinitely.
void loop() { digitalWrite(relayPin, LOW); delay(3000); digitalWrite(relayPin, HIGH); delay(3000); }
