Lesson 25: Water Level Sensor Module
In this lesson, you will learn how to measure water levels using Arduino. We’ll look at how a water level sensor can produce different voltage levels based on the water height and how the Arduino reads these voltage levels. This project is ideal for beginners as it provides practical experience with analog sensors and introduces basic concepts of processing sensor data on the Arduino platform.
ITEMS IN THIS KIT
Universal Maker Sensor Kit
94
Component Introduction
Purchase Link
Arduino UNO R3 or R4
../_images/Lesson_25_Water_level_uno_bb.png
Code Analysis
  1. Initializing the Sensor Pin:
    Before using the water level sensor, it’s pin number is defined using a constant variable. This makes the code more readable and easier to modify.
    const int sensorPin = A0;
  2. Setting Up Serial Communication:
    In the setup() function, the baud rate for serial communication is set. This is crucial for the Arduino to communicate with the computer’s serial monitor.
      Serial.begin(9600);  // Start serial communication at 9600 baud rate
  3. Reading Sensor Data and Outputting to Serial Monitor:
    The loop() function continuously reads the sensor’s analog value using analogRead() and outputs it to the serial monitor using Serial.println(). The delay(100) function makes the Arduino wait for 100 milliseconds before repeating the loop, controlling the rate of data reading and transmission.
      Serial.println(analogRead(sensorPin));  // Read the analog value of the sensor and print it to the serial monitor
      delay(100);                             // Wait for 100 milliseconds
