Lesson 24: Vibration Sensor Module (SW-420)
In this lesson, you will learn how to detect vibrations using a vibration sensor with an Arduino Uno. We’ll explore how the sensor signals the presence of vibrations to the Arduino, triggering it to display a message. This project is perfect for beginners to understand digital input processing and serial communication in Arduino. You’ll gain hands-on experience in reading sensor data and implementing conditional logic in your sketches.
Universal Maker Sensor Kit |
94 |
Component Introduction |
Purchase Link |
Arduino UNO R3 or R4 |
Code Analysis
The first line of code is a constant integer declaration for the vibration sensor pin. We use digital pin 7 to read the output from the vibration sensor.
const int sensorPin = 7;
In the
setup()function, we initialize the serial communication at a baud rate of 9600 to print readings from the vibration sensor to the serial monitor. We also set the vibration sensor pin as an input.void setup() { Serial.begin(9600); // Start serial communication at 9600 baud rate pinMode(sensorPin, INPUT); // Set the sensorPin as an input pin }
The
loop()function is where we continuously check for any vibrations detected by the sensor. If the sensor detects a vibration, it prints “Detected vibration…” to the serial monitor. If no vibration is detected, it prints “…”. The loop repeats every 100 milliseconds.void loop() { if (digitalRead(sensorPin)) { // Check if there is any vibration detected by the sensor Serial.println("Detected vibration..."); // Print "Detected vibration..." if vibration detected } else { Serial.println("..."); // Print "..." otherwise } // Add a delay to avoid flooding the serial monitor delay(100); }
