Lesson 14: Pulse Oximeter and Heart Rate Sensor Module (MAX30102)
In this lesson, you’ll learn how to measure heart rate using a MAX30102 sensor and Arduino Uno. You’ll learn to set up the sensor, read infrared values, calculate BPM, and average readings over time. This project is perfect for those interested in health monitoring with Arduino, combining hardware interfacing and software logic.
Warning
This project detects heart-rate optically. This method is tricky and prone to give false readings. So please DO NOT use it for actual medical diagnosis.
Universal Maker Sensor Kit |
94 |
Component Introduction |
Purchase Link |
Arduino UNO R3 or R4 |
To install the library, use the Arduino Library Manager and search for “SparkFun MAX3010x” and install it.
Code Analysis
Including Libraries & Initializing Global Variables:
The essential libraries are imported, the sensor object is instantiated, and global variables for data management are set.
#include <Wire.h> #include "MAX30105.h" #include "heartRate.h" MAX30105 particleSensor; // ... (other global variables)
Setup Function & Sensor Initialization:
The Serial communication is initialized at a baud rate of 9600. The sensor’s connection is checked, and if successful, an initialization sequence is run. An error message is displayed if the sensor isn’t detected.
void setup() { Serial.begin(9600); if (!particleSensor.begin(Wire, I2C_SPEED_FAST)) { Serial.println("MAX30102 not found."); while (1) ; // Infinite loop if sensor not detected. } // ... (further setup)
Reading IR Value & Checking for Heartbeat:
The IR value, which is indicative of the blood flow, is fetched from the sensor. The
checkForBeat()function assesses if a heartbeat is detected based on this value.long irValue = particleSensor.getIR(); if (checkForBeat(irValue) == true) { // ... (heartbeat detected actions) }
Calculating Beats Per Minute (BPM):
Upon detecting a heartbeat, the BPM is calculated based on the time difference since the last detected heartbeat. The code also ensures the BPM falls within a realistic range before updating the average.
long delta = millis() - lastBeat; beatsPerMinute = 60 / (delta / 1000.0); if (beatsPerMinute < 255 && beatsPerMinute > 20) { // ... (store and average BPM) }
Printing Values to the Serial Monitor:
The IR value, current BPM, and average BPM are printed to the Serial Monitor. Additionally, the code checks if the IR value is too low, suggesting the absence of a finger.
//Print the IR value, current BPM value, and average BPM value to the serial monitor Serial.print("IR="); Serial.print(irValue); Serial.print(", BPM="); Serial.print(beatsPerMinute); Serial.print(", Avg BPM="); Serial.print(beatAvg); if (irValue < 50000) Serial.print(" No finger?");
