Lesson 11: Photoresistor Module
In this lesson, you will learn how to measure light intensity using a photoresistor sensor with an Arduino Uno. We’ll cover reading and displaying the analog values from the sensor, which reflect the amount of light it detects. This project is ideal for beginners as it provides hands-on experience in working with sensors and understanding analog input on the Arduino platform. You’ll also improve your proficiency in serial communication by outputting sensor readings to the serial monitor.
ITEMS IN THIS KIT
Universal Maker Sensor Kit
94
Component Introduction
Purchase Link
Arduino UNO R3 or R4
../_images/Lesson_11_photoresistor_module_uno_bb.png
Code Analysis
  1. Setting Up the Sensor Pin and Serial Communication
    We start by defining the sensor pin and initializing serial communication in the setup function. The photoresistor is connected to the analog pin A0.
    const int sensorPin = A0;  // Pin connected to the photoresistor
      Serial.begin(9600);  // Start serial communication at 9600 baud rate
  2. Reading and Displaying Sensor Data
    In the loop function, we continuously read the analog value from the sensor and print it to the Serial Monitor. We also add a short delay to stabilize the readings.
      Serial.println(analogRead(sensorPin));  // Read and print the analog value
      delay(50);                              // Short delay to stabilize readings
