Lesson 53: Direction Indicator
This Arduino project initializes an OLED display and reads input from a joystick connected to analog pins A0 and A1. It continuously monitors the joystick’s position to determine its tilt direction and displays an appropriate arrow (up, down, left, or right) or a circle (if the joystick is centered) on the OLED display.
ITEMS IN THIS KIT
Universal Maker Sensor Kit
94
Component Introduction
Purchase Link
Arduino UNO R3 or R4
Joystick Module
OLED Display Module (SSD1306)
../_images/Lesson_53_Direction_indicatorr_uno_bb.png
To install the library, use the Arduino Library Manager and search for “Adafruit SSD1306” and “Adafruit GFX” and install it.
Code Analysis
  1. Including necessary libraries
    The project uses three libraries: Wire.h for I2C communication, Adafruit_GFX.h for graphics primitives, and Adafruit_SSD1306.h for OLED display control.
    #include <Wire.h>
    #include <Adafruit_GFX.h>
    #include <Adafruit_SSD1306.h>
  2. Defining constants and creating an OLED display object
    Constants for the OLED display dimensions and address are defined. The OLED display object is created with these parameters.
    #define SCREEN_WIDTH 128  // OLED display width, in pixels
    #define SCREEN_HEIGHT 64  // OLED display height, in pixels
    #define OLED_RESET -1  // Reset pin # (or -1 if sharing Arduino reset pin)
    #define SCREEN_ADDRESS 0x3C
    Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
  3. Pin definitions and threshold for the joystick
    The analog pins A0 and A1 are used for the joystick, and a threshold is defined to determine if the joystick is centered.
    const int xPin = A0;  // the VRX attach to
    const int yPin = A1;  // the VRY attach to
    const int threshold = 50;  // threshold to consider joystick in the center
  4. Setup function: initializing serial communication and the OLED display
    Serial communication is initialized for debugging, and the OLED display is initialized and cleared.
      Serial.begin(9600);
      if (!display.begin(SSD1306_SWITCHCAPVCC, SCREEN_ADDRESS)) {
        Serial.println(F("SSD1306 allocation failed"));
        for (;;);
      display.clearDisplay();
  5. Main loop: reading joystick values, determining direction, and displaying shapes
    The main loop reads the joystick values, determines the direction based on these values, and displays the corresponding shape on the OLED display.
    ../_images/Lesson_53_Code_Analysis.png
      int xValue = analogRead(xPin);
      int yValue = analogRead(yPin) * -1;
      Serial.print("X: ");
      Serial.print(xValue);
      Serial.print("|Y: ");
      Serial.println(-yValue);
      float yLine1 = line1(xValue);
      float yLine2 = line2(xValue);
      int relX = xValue - 512;
      int relY = -yValue - 512;
      if (abs(relX) < threshold && abs(relY) < threshold) {
        drawCircle();
      } else if (yValue > yLine1 && yValue > yLine2) {
        drawUpArrow();
      } else if (yValue < yLine1 && yValue < yLine2) {
        drawDownArrow();
      } else if (yValue < yLine1 && yValue > yLine2) {
        drawRightArrow();
      } else if (yValue > yLine1 && yValue < yLine2) {
        drawLeftArrow();
      display.display();
      delay(80);
  6. Helper functions: calculating lines and drawing shapes
    These functions help in calculating lines used for direction determination and drawing shapes on the OLED display.
    float line1(float x) {
      return x - 1023;
    float line2(float x) {
      return -x;
    void drawUpArrow() {
      display.fillTriangle(49, 30, 64, 15, 79, 30, WHITE);
      display.fillRect(59, 30, 10, 20, WHITE);
    void drawDownArrow() {
      display.fillTriangle(49, 36, 64, 51, 79, 36, WHITE);
      display.fillRect(59, 16, 10, 20, WHITE);
    void drawRightArrow() {
      display.fillTriangle(70, 15, 85, 30, 70, 45, WHITE);
      display.fillRect(50, 25, 20, 10, WHITE);
    void drawLeftArrow() {
      display.fillTriangle(60, 15, 45, 30, 60, 45, WHITE);
      display.fillRect(60, 25, 20, 10, WHITE);
    void drawCircle() {
      display.fillCircle(64, 32, 10, WHITE);
      display.fillCircle(64, 32, 8, BLACK);
Reference
