Lesson 13: Potentiometer Module
In this lesson, you’ll learn how to read the analog value of a potentiometer with an Arduino Uno. We’ll connect the potentiometer to pin A0 and use the Arduino to measure its value from 0 to 1023. This tutorial will walk you through setting up the circuit, writing code to read the sensor, and displaying the readings on the serial monitor. It’s a great project for beginners, providing hands-on experience with analog input and serial communication on the Arduino platform.
ITEMS IN THIS KIT
Universal Maker Sensor Kit
94
Component Introduction
Purchase Link
Arduino UNO R3 or R4
../_images/Lesson_13_potentiometer_module_uno_bb.png
Code Analysis
  1. This line of code defines the pin number to which the potentiometer is connected on the Arduino board.
    const int sensorPin = A0;
  2. The setup() function is a special function in Arduino that is executed only once when the Arduino is powered on or reset. In this project, the Serial.begin(9600) command initiates serial communication at a baud rate of 9600.
      Serial.begin(9600);
  3. The loop() function is the main function where the program runs repeatedly. In this function, the analogRead() function reads the analog value from the potentiometer and prints it to the serial monitor using Serial.println(). The delay(50) command makes the program wait for 50 milliseconds before taking the next reading.
      Serial.println(analogRead(sensorPin));
      delay(50);
