Lesson 19: Temperature and Humidity Sensor Module (DHT11)
In this lesson, you’ll learn how to measure temperature and humidity, as well as calculate the heat index using a DHT11 sensor with an Arduino Uno. We’ll cover reading and interpreting data from the DHT11 sensor, and displaying these values along with the heat index in both Celsius and Fahrenheit on the serial monitor. This project is perfect for Arduino beginners, providing hands-on experience with sensors and data handling in a simple yet engaging way.
Universal Maker Sensor Kit |
94 |
Component Introduction |
Purchase Link |
Arduino UNO R3 or R4 |
The kit may contain different versions of the DHT11 module. Please confirm the wiring method according to the module you have.
module |
diagram |
To install the library, use the Arduino Library Manager and search for “DHT sensor library” and install it.
Code Analysis
Inclusion of necessary libraries and definition of constants. This part of the code includes the DHT sensor library and defines the pin number and sensor type used in this project.
#include <DHT.h> #define DHTPIN 2 // Define the pin used to connect the sensor #define DHTTYPE DHT11 // Define the sensor type
Creation of DHT object. Here we create a DHT object using the defined pin number and sensor type.
DHT dht(DHTPIN, DHTTYPE); // Create a DHT object
This function is executed once when the Arduino starts. We initialize the serial communication and the DHT sensor in this function.
void setup() { Serial.begin(9600); Serial.println(F("DHT11 test!")); dht.begin(); // Initialize the DHT sensor }
Main loop. The
loop()function runs continuously after the setup function. Here, we read the humidity and temperature values, calculate the heat index, and print these values to the serial monitor. If the sensor read fails (returns NaN), it prints an error message.Note
The heat index is a way to measure how hot it feels outside by combining the air temperature and the humidity. It is also called the “felt air temperature” or “apparent temperature”.
void loop() { delay(2000); float h = dht.readHumidity(); float t = dht.readTemperature(); float f = dht.readTemperature(true); if (isnan(h) || isnan(t) || isnan(f)) { Serial.println(F("Failed to read from DHT sensor!")); return; } float hif = dht.computeHeatIndex(f, h); float hic = dht.computeHeatIndex(t, h, false); Serial.print(F("Humidity: ")); Serial.print(h); Serial.print(F("% Temperature: ")); Serial.print(t); Serial.print(F("°C ")); Serial.print(f); Serial.print(F("°F Heat index: ")); Serial.print(hic); Serial.print(F("°C ")); Serial.print(hif); Serial.println(F("°F")); }
