Lesson 29: Traffic Light Module
In this lesson, you will learn how to use Arduino to control a mini LED traffic light. We’ll cover programming the Arduino Uno to cycle through green, yellow, and red lights, simulating a real traffic signal. This project is ideal for beginners as it provides practical experience in coding light sequences and timing controls on the Arduino platform.
Universal Maker Sensor Kit |
94 |
Component Introduction |
Purchase Link |
Arduino UNO R3 or R4 |
Code Analysis
Before any operations, we define constants for the pins where LEDs are connected. This makes our code easier to read and modify.
const int rledPin = 9; //red const int yledPin = 8; //yellow const int gledPin = 7; //green
Here, we specify the pin modes for our LED pins. They are all set to
OUTPUTbecause we intend to send voltage to them.
void setup() { pinMode(rledPin, OUTPUT); pinMode(yledPin, OUTPUT); pinMode(gledPin, OUTPUT); }
This is where our traffic light cycle logic is implemented. The sequence of operations is:
Turn the green LED on for 5 seconds.
Blink the yellow LED three times (each blink lasts for 0.5 seconds).
Turn the red LED on for 5 seconds.
void loop() { digitalWrite(gledPin, HIGH); delay(5000); digitalWrite(gledPin, LOW); digitalWrite(yledPin, HIGH); delay(500); digitalWrite(yledPin, LOW); delay(500); digitalWrite(yledPin, HIGH); delay(500); digitalWrite(yledPin, LOW); delay(500); digitalWrite(yledPin, HIGH); delay(500); digitalWrite(yledPin, LOW); delay(500); digitalWrite(rledPin, HIGH); delay(5000); digitalWrite(rledPin, LOW); }
