Lesson 09: Joystick Module
In this lesson, you will learn how to read values from a joystick module using an Arduino Uno. We will explore connecting the joystick’s X and Y axes to the Arduino and how to display their values on the serial monitor. Additionally, we’ll cover the usage of a switch button on the joystick. This project is perfect for beginners, offering hands-on experience with analog and digital inputs on the Arduino platform.
Universal Maker Sensor Kit |
94 |
Component Introduction |
Purchase Link |
Arduino UNO R3 or R4 |
Code Analysis
Pin Definitions:
const int xPin = A0; //the VRX attach to const int yPin = A1; //the VRY attach to const int swPin = 8; //the SW attach to
Constants for the joystick pins are defined.
xPinandyPinare analog pins for the joystick’s X and Y axes.swPinis a digital pin for the joystick’s switch.Setup Function:
void setup() { pinMode(swPin, INPUT_PULLUP); Serial.begin(9600); }
Initializes
swPinas an input with a pull-up resistor, essential for the switch’s functionality. Starts serial communication at 9600 baud.Main Loop:
void loop() { Serial.print("X: "); Serial.print(analogRead(xPin)); // print the value of VRX Serial.print("|Y: "); Serial.print(analogRead(yPin)); // print the value of VRY Serial.print("|Z: "); Serial.println(digitalRead(swPin)); // print the value of SW delay(50); }
Continuously reads and prints the values from the joystick’s axes and switch to the Serial Monitor, with a delay of 50 ms between readings.
