Lesson 01: Button Module
In this lesson, you will learn how a button interacts with an LED using Arduino. We’ll see how pressing the button lights up the LED and releasing it turns off the LED. This project is ideal for beginners as it provides a practical understanding of input and output operations on the Arduino platform.
ITEMS IN THIS KIT
Universal Maker Sensor Kit
94
Component Introduction
Purchase Link
Arduino UNO R3 or R4
Button Module
../_images/Lesson_01_Button_Module_uno_bb.png
Code Analysis
  1. Initialization of Pins
    The pins for the button and LED are defined and initialized. The buttonPin is set as an input to read the button’s state, and ledPin is set as an output to control the LED.
    Most Arduino boards have a pin connected to an on-board LED in series with a resistor. The constant LED_BUILTIN is the number of the pin to which the on-board LED is connected. Most boards have this LED connected to digital pin 13.
    const int buttonPin = 12;        // Pin number for the button
    const int ledPin = LED_BUILTIN;  // Pin number for the LED
    int buttonState = 0;  // Variable to hold the current state of the button
  2. Setup Function
    This function runs once and sets up the pin modes. pinMode(buttonPin, INPUT) configures the button pin as an input. pinMode(ledPin, OUTPUT) sets the LED pin as an output.
      pinMode(buttonPin, INPUT);  // Initialize buttonPin as an input pin
      pinMode(ledPin, OUTPUT);    // Initialize ledPin as an output pin
  3. Main Loop Function
    This is the core of the program where the button state is continuously read and the LED state is controlled. digitalRead(buttonPin) reads the button’s state. If the button is pressed (state is LOW), the LED is turned on by digitalWrite(ledPin, HIGH). If not pressed, the LED is turned off (digitalWrite(ledPin, LOW)).
    The button module used in this project has an internal pull-up resistor (see its schematic diagram), causing the button to be at a low level when pressed and remain at a high level when released.
      // Read the current state of the button
      buttonState = digitalRead(buttonPin);
      // Check if the button is pressed (LOW)
      if (buttonState == LOW) {
        digitalWrite(ledPin, HIGH);  // Turn the LED on
      } else {
        digitalWrite(ledPin, LOW);  // Turn the LED off
