Lesson 31: Centrifugal Pump
In this lesson, you’ll learn how to control a centrifugal pump with an Arduino Uno R3 or R4 and an L9110 motor control board. You’ll discover how to set up and program the Arduino to start the pump in one direction, run it for a specific duration, and then stop it. This hands-on experience is ideal for beginners and offers fundamental insight into managing motor operations and understanding output controls in Arduino projects.
Universal Maker Sensor Kit |
94 |
Component Introduction |
Purchase Link |
Arduino UNO R3 or R4 |
Code Analysis
Two pins are defined for controlling the motor, specifically
motorB_1AandmotorB_2A. These pins will connect to the L9110 motor control board to control the direction and speed of the motor.const int motorB_1A = 9; const int motorB_2A = 10;
Configuring the pins and controlling the motor:
The
setup()function initializes the pins asOUTPUTwhich means they can send signals to the motor control board.The
analogWrite()function is used to set the motor speed. Here, setting one pin toHIGHand the other toLOWmakes the pump spin in one direction. After a 5-second delay, both pins are set to 0, turning off the motor.
void setup() { pinMode(motorB_1A, OUTPUT); // set pump pin 1 as output pinMode(motorB_2A, OUTPUT); // set pump pin 2 as output analogWrite(motorB_1A, HIGH); analogWrite(motorB_2A, LOW); delay(5000);// wait for 5 seconds analogWrite(motorB_1A, 0); // turn off the pump analogWrite(motorB_2A, 0); }
