Lesson 41: Heart rate monitor
This Arduino project aims to build a simple Heart Rate Monitor using a MAX30102 pulse oximeter sensor and an SSD1306 OLED Display. The code takes measurements of the heart rate by determining the time between heartbeats. By taking four measurements, it computes their average and presents the resultant average heart rate on an OLED screen. If the sensor doesn’t detect a finger, it sends a prompt to the user to position their finger correctly on the sensor.
Universal Maker Sensor Kit |
94 |
Component Introduction |
Purchase Link |
Arduino UNO R3 or R4 |
To install the library, open the Arduino Library Manager, search for “SparkFun MAX3010x” , “Adafruit SSD1306” , and “Adafruit GFX”, then install them.
Code Analysis
The main principle behind this project is to capture the pulsation of blood flow through a finger using the MAX30102 sensor. As blood pumps through the body, it causes tiny changes in the volume of blood in the vessels of the fingertip. By shining light through the finger and measuring the amount of light that gets absorbed or reflected back, the sensor detects these minute volume changes. The time interval between subsequent pulses is then used to calculate the heart rate in beats per minute (BPM). This value is then averaged over four measurements and displayed on the OLED screen.
Library Inclusions and Initial Declarations:
The code begins by including necessary libraries for the OLED display, MAX30102 sensor, and heart rate calculation. Additionally, the configuration for the OLED display and the variables for heart rate calculation are declared.
#include <Adafruit_GFX.h> // OLED libraries #include <Adafruit_SSD1306.h> #include <Wire.h> #include "MAX30105.h" // MAX3010x library #include "heartRate.h" // Heart rate calculating algorithm // ... Variables and OLED configuration
In this project, we’ve also whipped up a couple of bitmaps. The
PROGMEMkeyword denotes that the array is stored in the program memory of the Arduino microcontroller. Storing data in program memory(PROGMEM) instead of RAM can be helpful for large amounts of data, which would otherwise take up too much space in RAM.static const unsigned char PROGMEM beat1_bmp[] = {...} static const unsigned char PROGMEM beat2_bmp[] = {...}
Setup Function:
Initializes I2C communication, starts serial communication, initializes the OLED display, and sets up the MAX30102 sensor.
void setup() { Wire.setClock(400000); Serial.begin(9600); display.begin(SSD1306_SWITCHCAPVCC, SCREEN_ADDRESS); // ... Rest of the setup code
Main Loop:
The core functionality resides here. The IR value is read from the sensor. If a finger is detected (IR value greater than 50,000), the program checks if a heartbeat is sensed. When a heartbeat is detected, the OLED screen displays the BPM and the time between heartbeats is used to calculate BPM. Otherwise, it prompts the user to place their finger on the sensor.
We have also prepared two bitmaps with heartbeats, and by switching between these two bitmaps, we can achieve a dynamic visual effect.
void loop() { // Get IR value from sensor long irValue = particleSensor.getIR(); //If a finger is detected if (irValue > 50000) { // Check if a beat is detected if (checkForBeat(irValue) == true) { // Update OLED display // Calculate the BPM // Calculate the average BPM //Print the IR value, current BPM value, and average BPM value to the serial monitor // Update OLED display } } else { // ... Prompt to place the finger on the sensor } }
