Lesson 02: Capacitive Soil Moisture Module
In this lesson, you will learn how to connect a capacitive soil moisture sensor to an Arduino and interpret its readings. The project includes reading the sensor’s analog output with the Arduino and understanding that lower readings indicate higher soil moisture levels. You’ll gain practical experience in handling analog input and serial communication with the Arduino by using the provided code as a hands-on example.
Universal Maker Sensor Kit |
94 |
Component Introduction |
Purchase Link |
Arduino UNO R3 or R4 |
Code Analysis
Defining the sensor pin:
This line of code declares a constant integer
sensorPinand assigns it the value ofA0, which is the analog input pin the sensor is connected to.const int sensorPin = A0;
Setup function:
The
setup()function is executed once when the program starts. It initializes serial communication at 9600 baud rate. This setup is necessary for sending data to the serial monitor.void setup() { Serial.begin(9600); }
Loop function:
The
loop()function runs continuously aftersetup(). It reads the sensor value from pin A0 usinganalogRead()and prints this value to the serial monitor. Thedelay(500)statement pauses the loop for 500 milliseconds before the next reading, thus controlling the rate of data acquisition.void loop() { Serial.println(analogRead(A0)); delay(500); }
