Lesson 17: Rotary Encoder Module
In this lesson, you will learn how to monitor and control a rotary encoder with an Arduino Uno. We’ll cover tracking the rotation direction (clockwise or counterclockwise), counting rotations, and detecting button presses on the encoder module. This project is ideal for those seeking to enhance their understanding of rotary encoders and input/output operations in Arduino, providing practical insight into physical control systems.
ITEMS IN THIS KIT
Universal Maker Sensor Kit
94
Component Introduction
Purchase Link
Arduino UNO R3 or R4
../_images/Lesson_17_Rotary_encoder_uno_bb.png
Code Analysis
  1. Setup and Initialization
      pinMode(CLK, INPUT);
      pinMode(DT, INPUT);
      pinMode(SW, INPUT_PULLUP);
      Serial.begin(9600);
      lastStateCLK = digitalRead(CLK);
    In the setup function, the digital pins connected to the encoder’s CLK and DT are set as inputs. The SW pin, which is connected to the button, is set as an input with an internal pull-up resistor. This setup prevents the need for an external pull-up resistor. The Serial communication is started at a baud rate of 9600 to enable data visualization on the Serial Monitor. The initial state of the CLK pin is read and stored.
  2. Main Loop: Reading Encoder and Button State
      currentStateCLK = digitalRead(CLK);
      if (currentStateCLK != lastStateCLK && currentStateCLK == 1) {
        if (digitalRead(DT) != currentStateCLK) {
          counter--;
          currentDir = "CCW";
        } else {
          counter++;
          currentDir = "CW";
        Serial.print("Direction: ");
        Serial.print(currentDir);
        Serial.print(" | Counter: ");
        Serial.println(counter);
      lastStateCLK = currentStateCLK;
      int btnState = digitalRead(SW);
      if (btnState == LOW) {
        if (millis() - lastButtonPress > 50) {
          Serial.println("Button pressed!");
        lastButtonPress = millis();
      delay(1);
    In the loop function, the program continually reads the current state of the CLK pin. If there’s a change in the state, it implies a rotation has occurred. The direction of rotation is determined by comparing the states of CLK and DT pins. If they are different, it indicates counterclockwise (CCW) rotation; otherwise, it’s clockwise (CW). The encoder’s count is incremented or decremented accordingly. This information is then sent to the Serial Monitor.
    The button state is read from the SW pin. If it’s LOW (pressed), a debounce mechanism is implemented by checking the time elapsed since the last button press. If more than 50 milliseconds have passed, it’s considered a valid press, and a message is sent to the Serial Monitor. The delay(1) at the end helps in debouncing.
