For Raspberry Pi Pico W
Raspberry Pi Pico W users, please check out the following tutorial. This tutorial is suitable for Raspberry Pi Pico and Pico W. We will use MicroPython to program the Pi Pico W and write a simple code example for each component to help you get started quickly.
MicroPython is a version of the Python programming language for microcontrollers, such as your Raspberry Pi Pico W. MicroPython lets you use your Python knowledge to write code to interact with electronics components.
- Lesson 01: Button Module
- Lesson 02: Capacitive Soil Moisture Module
- Lesson 03: Flame Sensor Module
- Lesson 04: Gas Sensor Module (MQ-2)
- Lesson 05: Gyroscope & Accelerometer Module (MPU6050)
- Lesson 06: Hall Sensor Module
- Lesson 07: Infrared Speed Sensor Module
- Lesson 08: IR Obstacle Avoidance Sensor Module
- Lesson 09: Joystick Module
- Lesson 10: PCF8591 ADC DAC Converter Module
- Lesson 11: Photoresistor Module
- Lesson 12: PIR Motion Module (HC-SR501)
- Lesson 13: Potentiometer Module
- Lesson 14: Pulse Oximeter and Heart Rate Sensor Module (MAX30102)
- Lesson 15: Raindrop Detection Module
- Lesson 16: Real Time Clock Module (DS1302)
- Lesson 17: Rotary Encoder Module
- Lesson 18: Temperature Sensor Module (DS18B20)
- Lesson 19: Temperature and Humidity Sensor Module (DHT11)
- Lesson 20: Temperature, Humidity & Pressure Sensor (BMP280)
- Lesson 21: Time of Flight Micro-LIDAR Distance Sensor (VL53L0X)
- Lesson 22: Touch Sensor Module
- Lesson 23: Ultrasonic Sensor Module (HC-SR04)
- Lesson 24: Vibration Sensor Module (SW-420)
- Lesson 25: Water Level Sensor Module
- Lesson 26: I2C LCD 1602
- Lesson 27: OLED Display Module (SSD1306)
- Lesson 28: RGB LED Module
- Lesson 29: Traffic Light Module
- Lesson 30: Relay Module
- Lesson 31: Centrifugal Pump
- Lesson 32: Passive Buzzer Module
- Lesson 33: Servo Motor (SG90)
- Lesson 34: TT Motor
