Lesson 07: Infrared Speed Sensor Module
In this lesson, you will learn how to measure motor speed using a speed sensor module with an Arduino Uno. We’ll cover setting up the motor and sensor, programming the Arduino to calculate revolutions per second, and displaying the data. This project is great for intermediate learners as it provides hands-on experience with real-time data processing and motor control on the Arduino platform.
ITEMS IN THIS KIT
Universal Maker Sensor Kit
94
Component Introduction
Purchase Link
Arduino UNO R3 or R4
TT Motor
L9110 Motor Driver Module
../_images/Lesson_07_speed_module_uno_bb.png
Code Analysis
  1. Setting up the pins and initializing variables. Here, we define the pins for the motor and the speed sensor. We also initialize variables that will be used to measure and calculate the speed of the motor.
    // Define the sensor and motor pins
    const int sensorPin = 11;
    const int motorB_1A = 9;
    const int motorB_2A = 10;
    // Define variables for measuring speed
    unsigned long start_time = 0;
    unsigned long end_time = 0;
    int steps = 0;
    float steps_old = 0;
    float temp = 0;
    float rps = 0;
  2. Initialization in the setup() function. This section sets up the serial communication, configures the pins’ modes, and sets the initial motor speed.
      Serial.begin(9600);
      pinMode(sensorPin, INPUT);
      pinMode(motorB_1A, OUTPUT);
      pinMode(motorB_2A, OUTPUT);
      analogWrite(motorB_1A, 160);
      analogWrite(motorB_2A, 0);
  3. Measuring the motor’s speed in the loop() function. In this segment, the motor’s steps are measured for a duration of 1 second. These steps are then used to calculate the revolutions per second (rps), which is then printed to the serial monitor.
    millis() returns the number of milliseconds passed since the Arduino board began running the current program.
      start_time = millis();
      end_time = start_time + 1000;
      while (millis() < end_time) {
        if (digitalRead(sensorPin)) {
          steps = steps + 1;
          while (digitalRead(sensorPin))
      temp = steps - steps_old;
      steps_old = steps;
      rps = (temp / 20);
      Serial.print("rps:");
      Serial.println(rps);
