š Ready to explore and create with us? Click [here] and join today!
Lesson 05: Gyroscope & Accelerometer Module (MPU6050)ļ
In this lesson, you will learn how to use the MPU6050 sensor with an Arduino to measure acceleration, rotation, and temperature. Weāll explore initializing the sensor, setting its ranges, and reading data to display on the serial monitor. This project offers a hands-on approach to working with motion sensors and integrating them with Arduino, perfect for those looking to dive into the world of electronics and sensor data handling.
Required Componentsļ
Itās definitely convenient to buy a whole kit, hereās the link:
Universal Maker Sensor Kit |
94 |
Component Introduction |
Purchase Link |
Arduino UNO R3 or R4 |
Wiringļ
Codeļ
To install the library, use the Arduino Library Manager and search for āAdafruit MPU6050ā and install it.
Code Analysisļ
The code starts by including the necessary libraries and creating an object for the MPU6050 sensor. This code uses the Adafruit_MPU6050 library, Adafruit_Sensor library, and Wire library. The
Adafruit_MPU6050library is used to interact with the MPU6050 sensor and retrieve acceleration, rotation, and temperature data. TheAdafruit_Sensorlibrary provides a common interface for various types of sensors. TheWirelibrary is used for I2C communication, which is necessary to communicate with the MPU6050 sensor.Note
#include <Adafruit_MPU6050.h> #include <Adafruit_Sensor.h> #include <Wire.h> Adafruit_MPU6050 mpu;
The
setup()function initializes the serial communication and checks if the sensor is detected. If the sensor is not found, the Arduino enters an infinite loop with a āFailed to find MPU6050 chipā message. If found, the accelerometer range, gyro range, and filter bandwidth are set, and a delay is added for stability.void setup(void) { // Initialize the serial communication Serial.begin(9600); // Check if the MPU6050 sensor is detected if (!mpu.begin()) { Serial.println("Failed to find MPU6050 chip"); while (1) { delay(10); } } Serial.println("MPU6050 Found!"); // set accelerometer range to +-8G mpu.setAccelerometerRange(MPU6050_RANGE_8_G); // set gyro range to +- 500 deg/s mpu.setGyroRange(MPU6050_RANGE_500_DEG); // set filter bandwidth to 21 Hz mpu.setFilterBandwidth(MPU6050_BAND_21_HZ); // Add a delay for stability delay(100); }
In the
loop()function, the program creates events to store the sensor readings and then retrieves the readings. The acceleration, rotation, and temperature values are then printed to the serial monitor.void loop() { // Get new sensor events with the readings sensors_event_t a, g, temp; mpu.getEvent(&a, &g, &temp); // Print out the acceleration, rotation, and temperature readings // ... // Add a delay to avoid flooding the serial monitor delay(1000); }
