Lesson 44: Digital Dice
This program simulates a dice roll using an OLED display. The simulation is triggered by shaking the vibration switch, causing the display to cycle through numbers 1 to 6, akin to rolling a dice. The display halts after a short duration, revealing a randomly selected number that represents the dice roll outcome.
Universal Maker Sensor Kit |
94 |
Component Introduction |
Purchase Link |
Arduino UNO R3 or R4 |
To install the library, use the Arduino Library Manager and search for “Adafruit SSD1306” and “Adafruit GFX” and install it.
Code Analysis
A comprehensive breakdown of the code:
Initialization of variables:
vibPin: Digital pin connected to the vibration sensor.Volatile variables:
rolling: A volatile flag that indicates the dice’s rolling status. It is volatile as it is accessed within both the interrupt service routine and the main program.setup():Configures the vibration sensor’s input mode. Assigns an interrupt to the sensor to trigger the rollDice function upon state change. Initializes the OLED display.
loop():Continuously checks if
rollingis true, displaying a random number between 1 and 6 during this state. The rolling ceases if the sensor has been shaken for over 500 milliseconds.rollDice():The interrupt service routine for the vibration sensor. It initiates the dice roll when the sensor is shaken by recording the current time.
displayNumber():Displays a selected number on the OLED screen.
