Lesson 18: Temperature Sensor Module (DS18B20)
In this lesson, you’ll learn how to read temperature data from a DS18B20 sensor using Arduino. We’ll cover using the DallasTemperature library to communicate with the sensor and display readings in both Celsius and Fahrenheit on the Serial Monitor. This project is ideal for Arduino beginners, providing practical experience with temperature sensors and data processing.
ITEMS IN THIS KIT
Universal Maker Sensor Kit
94
Component Introduction
Purchase Link
Arduino UNO R3 or R4
../_images/Lesson_18_DS18B20_uno_bb.png
To install the library, use the Arduino Library Manager and search for “DallasTemperature” and install it.
Code Analysis
  1. Library inclusion
    The inclusion of the OneWire and DallasTemperature libraries allows communication with the DS18B20 sensor.
    #include <OneWire.h>
    #include <DallasTemperature.h>
  2. Defining the sensor data pin
    The DS18B20 is connected to digital pin 2 of the Arduino.
    #define ONE_WIRE_BUS 2
  3. Initializing the sensor
    The OneWire instance and DallasTemperature object are created and initialized.
    OneWire oneWire(ONE_WIRE_BUS);
    DallasTemperature sensors(&oneWire);
  4. Setup function
    The setup() function initializes the sensor and sets up serial communication.
    void setup(void)
       sensors.begin();       // Start up the library
       Serial.begin(9600);
  5. Main loop
    In the loop() function, the program requests temperature readings and prints them in both Celsius and Fahrenheit.
    void loop(void)
       sensors.requestTemperatures();
       Serial.print("Temperature: ");
       Serial.print(sensors.getTempCByIndex(0));
       Serial.print("℃ | ");
       Serial.print((sensors.getTempCByIndex(0) * 9.0) / 5.0 + 32.0);
       Serial.println("℉");
       delay(500);
