Learn about the Components in Your Kit
After opening the package, please check whether the quantity of components is compliance with product description and whether all components are in good condition.
The following is an introduction to each component, including its working principle and corresponding project. Each component has a simple code example to help you get started quickly.
Basic
Sensor
- Button Module
- Capacitive Soil Moisture Module
- Flame Sensor Module
- Gas/Smoke Sensor Module (MQ2)
- Gyroscope & Accelerometer Module (MPU6050)
- Hall Sensor Module
- Infrared Speed Sensor Module
- IR Obstacle Avoidance Sensor Module
- Joystick Module
- PCF8591 ADC DAC Converter Module
- Photoresistor Module
- PIR Motion Module (HC-SR501)
- Potentiometer Module
- Pulse Oximeter and Heart Rate Sensor Module (MAX30102)
- Raindrop Detection Module
- Real Time Clock Module (DS1302)
- Rotary Encoder Module
- Temperature Sensor Module (DS18B20)
- Temperature and Humidity Sensor Module (DHT11)
- Temperature, Humidity & Pressure Sensor (BMP280)
- Time of Flight Micro-LIDAR Distance Sensor (VL53L0X)
- Touch Sensor Module
- Ultrasonic Sensor Module (HC-SR04)
- Vibration Sensor Module (SW-420)
- Water Level Sensor Module
Display
Actuator
Wireless & IoT
Power
