๐ Ready to explore and create with us? Click [here] and join today!
OLED Display Module (SSD1306)๏
An OLED (Organic Light-Emitting Diode) display module is a device that can display text, graphics and images on a thin and flexible screen using organic materials that emit light when electric current is applied.
The SSD1306 I2C OLED display module operates by controlling an OLED (Organic Light-Emitting Diode) display using the powerful single-chip CMOS OLED driver controller, the SSD1306. This controller manages all RAM buffering and demands minimal effort from the connected microcontroller, such as an Arduino. OLED displays are renowned for their extremely light and potentially flexible nature, producing brighter and crisper images compared to traditional displays due to being almost paper-thin.
The main advantage of an OLED Display is that it emits its own light and doesnโt need another source of backlight. Due to this, OLED Displays often have better contrast, brightness and viewing angles when compared to LCD displays.
Another important feature of OLED Displays is deep black levels. Since each pixel emits its own light in an OLED Display, to produce black color, the individual pixel can be turned OFF.
Due to lower power consumption (only pixels which are lit up draw current), OLED displays are also popular in battery operated devices like Smart Watches, Health Trackers and other wearables.
Pinout๏
VIN: This is the power pin.
GND: Common ground for power and logic.
SCL: The serial clock pin for the I2C interface.
SDA: The serial data pin for the I2C interface.
Example๏
Lesson 27: OLED Display Module (SSD1306) (Arduino UNO)
Lesson 27: OLED Display Module (SSD1306) (Raspberry Pi Pico)
Lesson 27: OLED Display Module (SSD1306) (Raspberry Pi)
Lesson 41: Heart rate monitor (Arduino UNO)
Lesson 44: Digital Dice (Arduino UNO)
Lesson 52: Tilt Direction Indicator (Arduino UNO)
Lesson 53: Direction Indicator (Arduino UNO)
Lesson 39: Heart rate monitor (ESP32)
Lesson 42: Digital Dice (ESP32)
