TT Motor
../_images/34_tt_motor.png
A TT motor is a type of DC motor that has a gearbox attached to it. The gearbox reduces the speed of the motor and increases its torque. A TT motor is commonly used in applications such as driving wheels, propellers, fans, among others. A TT motor has two wires: a positive wire and a negative wire. The positive wire is usually red and the negative wire is usually black.
A TT DC gearbox motor with a 1:48 gear ratio is used in the product, it comes with 2 x 200mm wires with 0.1” male connectors that fit into a breadboard. Perfect for plugging into a breadboard or terminal block.
You can power these motors with 3 ~ 6VDC, but of course, they will go a little faster at higher voltages.
Technical Details
  • Rated Voltage: 3~6V
  • Continuous No-Load Current: 150mA +/- 10%
  • Min. Operating Speed (3V): 90+/- 10% RPM
  • Min. Operating Speed (6V): 200+/- 10% RPM
  • Stall Torque (3V): 0.4kg.cm
  • Stall Torque (6V): 0.8kg.cm
  • Gear Ratio: 1:48
  • Body Dimensions: 70 x 22 x 18mm
  • Wires Length: 200mm & 28 AWG
  • Weight: 30.6g
Dimensional Drawing
../_images/34_motor_size.png
Example
