Temperature and Humidity Sensor Module (DHT11)
The digital temperature and humidity sensor DHT11 is a composite sensor that contains a calibrated digital signal output of temperature and humidity. The technology of a dedicated digital modules collection and the temperature and humidity sensing technology are applied to ensure that the product has high reliability and excellent long-term stability.
Specification
Supply Voltage: 3.3V - 5V
Output Signal Type: Digital output
Temperature Measurement Range: 0-50℃ ± 2℃
Humidity Measurement Range: 20-90%RH ± 5%RH
Temperature Accuracy: ±2°C
Humidity Accuracy: ±5% RH
Pinout
VCC: This is the positive power supply input from the main control.
GND: Ground connection.
S: This pin is used for transmitting temperature and humidity data to the microcontroller using a single-wire bi-directional protocol.
Principle
Only three pins are available for use: VCC, GND, and DATA. The communication process begins with the DATA line sending start signals to DHT11, and DHT11 receives the signals and returns an answer signal. Then the host receives the answer signal and begins to receive 40-bit humidity and temperature data (8-bit humidity integer + 8-bit humidity decimal + 8-bit temperature integer + 8-bit temperature decimal + 8-bit checksum).
Schematic diagram
Example
Lesson 19: Temperature and Humidity Sensor Module (DHT11) (Arduino UNO)
Lesson 19: Temperature and Humidity Sensor Module (DHT11) (ESP32)
Lesson 19: Temperature and Humidity Sensor Module (DHT11) (Raspberry Pi Pico)
Lesson 19: Temperature and Humidity Sensor Module (DHT11) (Raspberry Pi)
Lesson 45: Plant Monitor (Arduino UNO)
Lesson 43: Plant Monitor (ESP32)
Lesson 48: Temperature and Humidity Monitoring with Adafruit IO (ESP32)
