Capacitive Soil Moisture Module
The Soil Moisture Module is a sensor used in agriculture to measure the moisture content of soil, helping farmers monitor soil moisture levels and determine when to water their crops. This capacitive soil moisture sensor differs from the resistive sensors on the market, using the principle of capacitive induction to detect soil moisture. It avoids the problem of easy corrosion in resistive sensors and greatly extends its working life.
Pinout
VCC: This is the positive power supply input from the main control.
GND: Ground connection.
AUOT: Analog output. The higher the soil moisture content, the lower the analog output value.
Principle
This capacitive soil moisture sensor is different from most of the resistive sensors on the market, using the principle of capacitive induction to detect soil moisture. It avoids the problem that resistive sensors are highly susceptible to corrosion and greatly extends its working life.
It is made of corrosion-resistant materials and has an excellent service life. Insert it into the soil around plants and monitor real-time soil moisture data. The module includes an on-board voltage regulator that allows it to operate over a voltage range of 3.3 ~ 5.5 V. It is ideal for low-voltage microcontrollers with 3.3 V and 5 V supplies.
The hardware schematic of the capacitive soil moisture sensor is shown below.
There is a fixed frequency oscillator, which is built with a 555 timer IC. The generated square wave is then fed to the sensor like a capacitor. However, for the square wave signal, the capacitor has a certain reactance or, for the sake of argument, a resistor with a pure ohmic resistor (10k resistor on pin 3) to form a voltage divider.
The higher the soil moisture, the higher the capacitance of the sensor. As a result, the square wave has less reactance, which reduces the voltage on the signal line, and the smaller the value of the analog input through the microcontroller.
Example
Lesson 02: Capacitive Soil Moisture Module (Arduino UNO)
Lesson 02: Capacitive Soil Moisture Module (Raspberry Pi Pico)
Lesson 02: Capacitive Soil Moisture Module (Raspberry Pi Pi)
Lesson 45: Plant Monitor (Arduino UNO)
Lesson 43: Plant Monitor (ESP32)
